96 2dr xj build - JeepForum.com
post #1 of 59 Old 06-10-2012, 12:26 AM Thread Starter
davyboyXJ
96 2dr xj build
so i bought this cherokee for $300. its a 1996 xj 2dr 5 spd 4.0 w/117,xxx on the clock. all it needed was a grille and fender and it was perfect. my intentions with this xj is to build a trails/rock crawler-rig. and here is my process and updates. enjoy!
davyboyXJ is offline
post #2 of 59 Old 06-10-2012, 12:27 AM Thread Starter
davyboyXJ
this is the day i drive it home after i threw a grille and driver fender on. i sprayed the wheels and grille and headlight bezels flat black
post #3 of 59 Old 06-10-2012, 12:29 AM Thread Starter
davyboyXJ
i had 31" cooper stt's and 15x8 american racing mojave's -15 et laying around and threw them on. also washed n waxed to see how good the paint still was. not too bad
post #4 of 59 Old 06-10-2012, 12:33 AM Thread Starter
davyboyXJ
ok i know 31's on stock suspension is lame. gotcha. im going with a 4.5" long arm lift and sye this week, so pics to come. but for now, ive trimmed the stock flares, eliminated the flare inner bracket and notched and folded the actual innner fender. also, the truck had a bent bumper when i bought it. i had to cut the driver side. so i cut the passenger side to basically have a stubby bumper. new bumber coming soon. not bad for a total of $600 invested.
post #5 of 59 Old 06-10-2012, 12:34 AM Thread Starter
davyboyXJ
took it to the local wheeling spot. diddent do
bad for stock suspension and open diff's.
post #6 of 59 Old 06-10-2012, 12:37 AM Thread Starter
davyboyXJ
ok so i noticed i could see my carpet from under the truck. pulled the carpet and holy rust. so i am doing complete front pans, and patching the rear sections. also the interior will be linex'ed.
post #7 of 59 Old 06-10-2012, 01:02 AM
Jeepnbo
good to see the 2doors still around! keep us updated with your floor patching, and make sure you post pics of the rear, i have the same spot goin and curious how i should go about fixing it since the gas tank is right under it
Jeepnbo is offline
post #8 of 59 Old 06-10-2012, 01:36 AM
millfire517
Looks like fun.
millfire517 is offline
post #9 of 59 Old 06-10-2012, 01:51 PM
Camfam07
yes and also keep us posted on your LINEX also I want to either go with a rubber flooring or maybe bedline it, keep posting I will check back up on it.
Camfam07 is offline
post #10 of 59 Old 06-10-2012, 10:44 PM Thread Starter
davyboyXJ
mostly finished. both front floorpans to the firewall were replaced. also rear sections were patched as well. frame was anti-rust treated and linex treated before and after patching. more pictures soon
post #11 of 59 Old 06-13-2012, 01:33 PM
Camfam07
Did you use a rattle can spray or linex and a spray gun?? Just curious looks amazing and I'm about to do mine and would like to get pretty close to that.
Camfam07 is offline
post #12 of 59 Old 06-28-2012, 07:24 PM Thread Starter
davyboyXJ
yea rattle can bedliner. for now. im ordering actual replacement pans to weld in soon. it turned out pretty well. i will probably have a local line-x place spray the floors once completely repaired.
post #13 of 59 Old 06-28-2012, 08:42 PM Thread Starter
davyboyXJ
removed flares minor cut and 31's. now for 4.5 lift and sye, front n rear steel bumpers and tow hooks, and rock sliders
post #14 of 59 Old 06-28-2012, 09:04 PM
Texsun
Looks great, keep up the work and for sure post pics of the 4.5inch LA setup!
Texsun is offline
post #15 of 59 Old 06-28-2012, 09:37 PM Thread Starter
davyboyXJ
thanks. cant beat it for less then $1000 total the way it sits. but lift should be done in a week or so.
