95' xj sport, canada eh! - Page 3 - JeepForum.com
post #31 of 59 Old 01-13-2013, 07:57 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Bought some U-Joints / Ball joints / fluids
$250.00
--1999 Cherokee Sport 2" Lift 30" rubber
---1995 Cherokee Sport 4.5" 32" rubber
XJ99XJ is offline
post #32 of 59 Old 01-21-2013, 08:14 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Ball joints were a mess!
XJ99XJ is offline
post #33 of 59 Old 01-21-2013, 08:15 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Much better now
u joints also
XJ99XJ is offline
post #34 of 59 Old 01-21-2013, 08:16 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
What can I use too plug the gap?!
XJ99XJ is offline
post #35 of 59 Old 01-21-2013, 10:36 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Outer axle seals?
April 2014 & 2015 COTM
MOBBiN is offline
post #36 of 59 Old 01-21-2013, 11:17 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Bingo
XJ99XJ is offline
post #37 of 59 Old 01-25-2013, 06:04 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
LCA bolts on stock control arms were seized too the sleeve, I had too replace with new ones from the "stealership" $70.00 later my IRO ADJUSTABLE's are good too go!
XJ99XJ is offline
post #38 of 59 Old 01-29-2013, 04:00 AM Thread Starter
XJ99XJ
1995 XJ Cherokee
Deja vu
XJ99XJ is offline
post #39 of 59 Old 02-08-2013, 05:17 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
DROVE IT 300km and took some pictures of the dupli-color bed armor job that I did roughly sixmonths ago
DAWGS, You like DAWGS?!
image-2875990172.jpg   image-783789305.jpg   image-1560376972.jpg   image-855774709.jpg   image-1161116481.jpg
XJ99XJ is offline
post #40 of 59 Old 02-08-2013, 05:19 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Going too replace front drivers side quarter panel! Just trying too decide on the color?
Maybe white or black
XJ99XJ is offline
post #41 of 59 Old 02-11-2013, 05:27 AM Thread Starter
XJ99XJ
1995 XJ Cherokee
Out with the old in with the new. IRO adjustable double sheer track bar and pro-comp steering stabilizer.
XJ99XJ is offline
post #42 of 59 Old 02-11-2013, 09:14 AM
VegasGT
1988 MJ Comanche
Looking good! Nice job on the bed armor! Is that spray or roll-on?
I usually buy cheap spray can bedliner but I am considering doing my flares and rockers soon. Im not really digging the colormatched look anymore.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #43 of 59 Old 02-11-2013, 09:33 AM Thread Starter
XJ99XJ
1995 XJ Cherokee
Thanks!
Ya I used the Dupli-color bed armor roll on kit w/ One gallon of liquid. $110.00 coverage on both bumpers, floor boards,running boards(inner & outter) little bit in the wheel well, lower doors 2-3 coats with a "little" bit left over.
Prepping is a big part I kind half assed it in a couple spots so ill need too use what's left too go back a patch a couple spots, nothing huge!
I think it's worth the money "so far"
I recommend NOT using the "roller kit" try and find just the product which ever you end up choosing, get a little extra too because you won't want too run out if you decide too do even more.
A couple cheap wire/paint brushes and sand paper, acetone too clean and a six pack too drink.
XJ99XJ is offline
post #44 of 59 Old 03-05-2013, 06:59 PM Thread Starter
XJ99XJ
1995 XJ Cherokee
Pretty bummed today, while I was cleaning out the back I decided too kick off the ice / snow build up off my rockers/end caps. I ended up kicking a whole in my passenger side rocker below the drivers door. ****!!!
I knew it was minor rust when I did the bed liner but I was hoping it atleast hold till spring/summer. Guess not
Time too replace it Should I go 2x6 box steel or slap a replacement rock from raybuck? Watta you guys rec?!
XJ99XJ is offline
post #45 of 59 Old 03-06-2013, 09:27 AM
MOBBiN
MOBBiN's Avatar
When something breaks (rusts out) you upgrade!
MOBBiN is offline
