94' xj interior UPGRADE - JeepForum.com
post #1 of 6 Old 04-07-2011, 11:06 PM Thread Starter
TheOneInLine
1994 XJ Cherokee
My ongoing project I started when I found my carpet soaked front to back. I still need to post updated pics of undercoating the entire interior. The brown paint is rust preventing specific paint. Next... I'm thinking of filling the interior frame channels with spray foam, to add strength, sound deadening and added insulation for those cold nights snoozing in the back. The torch picture is a short I found from moisture attacking a wire.
TheOneInLine is offline
post #2 of 6 Old 04-08-2011, 06:11 PM
keepishop
1989 XJ Cherokee
DEH-5500 head unit?
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 6 Old 04-08-2011, 07:35 PM
Dbiked
I dont see how that little bit of insulation on the rails will do much to keep you warmer. But hey, let us know if it does.
And sense you're Bedlineing the floor, you might as well pop out the drain plugs, and get some rubber ones to cover them up.
How did your whole interior get soaked in the first place?
Utah jeep crew member #32
Dbiked is offline
post #4 of 6 Old 04-09-2011, 02:57 PM Thread Starter
TheOneInLine
1994 XJ Cherokee
Originally Posted by keepishop View Post
DEH-5500 head unit?
No its a DEH-P650.
The floor got wet from to small holes in the pan and many deep puddles. It came up from the bottom, I know that for sure. There's a rubber membrane under that carpet that prevents moisture from soaking down into the pad below. So for the extreme prolonged wet carpet from below finally seeped through to the top, by that time it was soaked and had a faint smell of mold. I'm going to drive it to the car wash and do a leak test after the undercoat interior is all said and done. When I know she's sealed up I'll reinstall the carpet. I would leave it out, though I like to sleep in the back, and cold metal doesn't sound nice. I'll post new pictures soon.
post #5 of 6 Old 04-09-2011, 03:05 PM
Hussler
1992 XJ Cherokee
Please do not use spray foam on areas prone to moisture, it will not seal out wetness but absorb it like a sponge.
Good luck on your project
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #6 of 6 Old 04-09-2011, 04:56 PM Thread Starter
TheOneInLine
1994 XJ Cherokee
That's the plan, thanks for the input, that's what we're hear for right.
Fuel rail and injector upgrade? Renix vacuum upgrade? HeepToJeep XJ Cherokee Technical Forum 4 04-20-2008 09:06 PM
Interior: Cherokee to GC upgrade midfat XJ Cherokee Technical Forum 0 08-29-2007 01:04 PM
Upgrade - Upgrade or swap out? jborie XJ Cherokee Technical Forum 0 01-18-2007 02:24 AM
Leather Interior Upgrade for 97-01 XJs DefaZ XJ Cherokee Technical Forum 6 11-27-2005 08:10 PM
head light upgrade and driving light upgrade 5150gunner XJ Cherokee Technical Forum 2 12-07-2003 11:51 PM
