94 project 4 door xj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > 94 project 4 door xj
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 03-09-2014, 02:49 PM   #1
TyWiseley
What should the next mod be. And any ideas on tire and size
TyWiseley is offline   Reply With Quote
Unread 03-09-2014, 04:19 PM   #2
uberxj92
1992 XJ Cherokee
What have you done so far?
Mods depend on your plans for using the rig.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline   Reply With Quote
Unread 03-09-2014, 04:26 PM   #3
uberxj92
1992 XJ Cherokee
http://orlando.craigslist.org/cto/4344949053.html
Unread 03-09-2014, 06:00 PM   #4
TyWiseley
No definitely not
Unread 03-09-2014, 06:01 PM   #5
TyWiseley
In from New York so it will be snow and mud. I have a 3 inch lift and that's pretty much it I haven't decided on rims or tires probably going with 31's and don't know what size rims. I need bumpers winch and maybe a throttle body spacer
Unread 03-09-2014, 08:33 PM   #6
uberxj92
1992 XJ Cherokee
Ok. Throttle body spacer big waste of time and money. Does nothing at all.
If you're buying rims I would suggest a 17" rim. 15's are expensive and hard to find used.
Search on here for bumper threads. Great advice there.
