93-99 XJ 4.5-5.5 Suspension Lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > 93-99 XJ 4.5-5.5 Suspension Lift
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Advance Adapters SYE Kits
Unread 02-26-2014, 02:19 PM   #1
Dallis04
What is the best suspension lift to get for a 90s XJ Cherokee for trail riding and off roading, I want to fit 33s.
Also is it a leaf spring suspension? Basically I need to know what is the best suspension lift to put the XJ and if long arm etc is necessary, I just need some guidance on suspension lifts for XJs
Thanks!
Dallis04 is offline   Reply With Quote
Unread 02-26-2014, 04:39 PM   #2
Motorcharge
1992 XJ Cherokee
If only there were some sort of pinned topics and ways to search for the thousands upon thousands of threads with this basic information.
|Project Motörcharge | XJ Non-Tech FAQ | Ammo Can Lock Box | Motorcycle Build|
WANTED: YJ Rollbar - PM for details.
Motorcharge is offline   Reply With Quote
Unread 02-26-2014, 06:31 PM   #3
VNilla
That really annoys me when people don't answer peoples simple questions on here. Anyway, I got you man.
If you want 33s you could get away with a 4.5 inch lift. You'd need a transfer case drop or a SYE neither of which are too expensive or difficult to do. You may also have to trim fenders depending on how hardcore wheeling you are doing.
You definitely want long arm. Just trust me. It will flex better and overall be better.
Your XJ does in fact have rear leaf springs. With most lift kits you can do AAL (add a leaf) or get a full new pack of leafs. You definitely don't want AAL.
I'd recommend going with a Rubicon Express lift kit. Good quality and price.
Any other questions just let me know.
VNilla is offline   Reply With Quote
Unread 02-27-2014, 05:01 AM   #4
Dallis04
Thanks guy, yeah i thought that is what forums were for, to ask questions and share advice and answers you stupid pr@$k.
Anyways, VNilla, I appreciate you taking the time to answer me. That really helps. I haven't found a XJ yet, but on the lookout.
I have been thinking that RE was the way to go after reading about them. So you suggested getting a new leaf set, why is that and how much is that?
Also what's long arm vs short arm?
Thanks
Unread 02-27-2014, 01:47 PM   #5
rda616
I would stay clear of rubicon express myself. The control arms are crap and you quickly grow tired of replacing hourglass bushings. The track bar is also poorly bent and quite thin.
Short arms use factory control arm mounting points and long arms use custom mounting points that can improve suspension geometry.
rda616 is offline   Reply With Quote
Unread 02-27-2014, 02:04 PM   #6
DNFJ
DNFJ's Avatar
Too bad these questions have been answered 1000s of times and it gets old. Do some research for yourself instead of asking us to do it for you.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Built Not Bought #704
DNFJ is offline   Reply With Quote
Unread 02-27-2014, 02:49 PM   #7
rugsucka
Forums are not for people to ask redundant questions that can be easily found with the search function.
If you don't know that the XJ is a leaf sprung rearend then you don't deserve to ask what the best lift is since you haven't even tried to do basic research.
Try the stickies at the top of the XJ technical section. It has multiple links to educate yourself about the basics and even a super helpful link called Lifts etc. which has reviews and tire fitment FAQS.
That's a fact, Jack.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is online now   Reply With Quote
Unread 02-28-2014, 07:43 AM   #8
VNilla
If you know your stuff then you shouldn't have to do much research. I've read your build thread. I know you could answer this kids simple questions without thinking.
1998 Cherokee
Breaking bolts and taking names.
Unread 02-28-2014, 07:56 AM   #9
DNFJ
DNFJ's Avatar
It's completely subjective that's why it's annoying, what I am building my rig for isn't the same as X,Y, or Z person.
Wanna climb rocks? Do you want LCOG or would you feel better being up slightly higher? 2.5-4.5" lift, long arms, etc
Wanna do jeepspeed type stuff? 5.5-6.5" lift, drop brackets, air bumps, etc
Wanna do mud? 4.5+ lift, and adj. short arms will do you just fine.
Plus budget, technical skill, etc.
No other person on this forum can tell you what will be best for you, and that's why these threads annoy the vets.
Also, OP, coils springs up front, leaf springs in the rear. A Jeep Cherokee has a truck suspension for all intensive purposes.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Unread 02-28-2014, 02:45 PM   #10
Motorcharge
1992 XJ Cherokee
And without even using the search function he can find answers to his exact questions in 5+ new threads on the first two pages of this section and that's not even getting into the stickies. You might not post here much, but those of us that do get sick of answering the same lift questions over, and over, and over pretty much every day because some can't be bothered to read the basic information that was compiled and stickied for their laziness in the first place.
Unread 02-28-2014, 02:46 PM   #11
Motorcharge
1992 XJ Cherokee
Intents. Also plenty of pickup trucks have leafs up front.
