88 cherokee 2.5l - JeepForum.com
post #1 of 7 Old 06-10-2013, 05:08 PM Thread Starter
Cherokeeboy
1988 XJ Cherokee
88 cherokee 2.5l
Hi I have a 2.5l cherokee xj. I was wondering would it kill the engine to out 33" tires on it?
Cherokeeboy is offline
post #2 of 7 Old 06-10-2013, 09:58 PM
Puck81
Auto or 5 spd?? Also, what mods do you have to run 33's?
Puck81 is offline
post #3 of 7 Old 06-11-2013, 05:09 AM
mschi772
1997 XJ Cherokee
I wouldn't run 33's on a 4.0 with stock gearing. If you change your gears, I'd say it would be fine.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #4 of 7 Old 06-11-2013, 05:16 AM
7179CJ5
1979 CJ5
What's the difference between having an auto or 5 speed, is one better than the other?
7179CJ5 is offline
post #5 of 7 Old 06-11-2013, 05:43 PM
mschi772
1997 XJ Cherokee
Your 88 2.5 should be paired to a Aisin-Warner AX5. I'm not super familiar with the AX5, but the AX15 that the 4.0 manuals use is a very good transmission. An 88 automatic would have been a...Chrysler A904 I think? Anyway, don't fret about the quality of your transmission. Some are better than others, but I don't think any of the XJ's trannies were truly bad.
The different transmissions have different gear ratios of their own necessitating different rear axle gear ratios. And unless the torque converter of an auto is locked, not all engine power is transferred directly through the transmission.
This calculator might be extremely handy for you. http://www.manoian.net/jeep/gear_ratio_calculator.html
I don't have the exact dimensions of the 2.5 and no time to do the math right now anyway, but I'd say that your ideal cruising RPM should be at 2500; probably about 3000 RPM more likely. Here's another link you might find useful that I just scrounged-up for you: http://www.jedi.com/obiwan/jeep/2.5Lpower.html
This is just based on my quick educated guesswork, so I might be off a little, but if I were you, I think regearing to 4.56 give or take. Maybe even 4.88 if your big into wheeling.
Asking the YJ guys might get you some more wisdom as many of them had/have your 2.5 and AX5 drivetrain.
P.S. Listing all other mods you're running can be very helpful.
mschi772 is offline
post #6 of 7 Old 06-12-2013, 07:57 PM
Nick05
1994 XJ Cherokee
bout time we got another 2.5 xj on here. we are few and far between. i know there are some yj's in my area running 35's with the 2.5(don't ask me how, mine does good to spin the 235's). the yj guys would be more knowledgeable since they have more 2.5's the most xj guys
Nick05 is online now
post #7 of 7 Old 06-16-2013, 11:01 AM Thread Starter
Cherokeeboy
1988 XJ Cherokee
It's a 4spd. Plus j would like to know how much lift is possible before t gets to be to much further jeep
