800-1000 whats the best/biggest lift deal out there? - JeepForum.com
post #1 of 9 Old 03-22-2012, 04:26 PM Thread Starter
jzoomer
i was trying to get a 6" kit at a killer deal but it fell through at the last minute and was wandering with my $800-$1000 budged for the best deal on a lift
i am looking for the most lift for the buck...
also looking for something tough
ride quality isn't really an issue for me
want to be able to take it to some mild trails,
i plan on going to the 1 ton steering upgrade soon to in case i run into some rocks or something in a hole... want to do OTK
what's the best deal out there, (i want to run 32's-33's)
oh and i don't mind to do some work/fab if i can save enough money doing it DIY to pay for a welder / bigger air compressor
i love getting my hands dirty but i also cant leave it in tear down for long cause it has to perform DD duties
parts i have that i could possibly use:
Leafs from an 88 chevy 1500 lwb model (how much lift would i get from these? using it as AAL or Bastard Pack?)
and thats about it right now lol..ive heard f150 front springs (how much lift does that give?)
jzoomer is offline
post #2 of 9 Old 03-22-2012, 04:54 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Read my Build thread , Link is in my Sig, I pieced together a RE 3.5" with full leafs and Bilstein 5100 shocks an some Rock Sliders for $1,000 if you trim and run proper bumpstops you can run 33's
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 9 Old 03-22-2012, 05:29 PM
Motorcharge
You don't need 6" for light wheeling. It creates a lot of drive line and suspension replacement/upgrade issues for no real reason. You're not going to get that height cheap.
Stick with a solid 3-4" lift and focus on building your axles. Swap the rear with a Ford 8.8 and regear it accordingly. You can find some good, cheap deals on them, they're more solid than Dana 44's and the kits to make them bolt on for the XJ's are under $300.
You're better off investing in skid plates and armor than upgrading to 1-ton steering.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 9 Old 03-22-2012, 07:07 PM Thread Starter
jzoomer
any input on how much lift my chevy leaf's would add? if i could use those and save a few hundred $$ that would be great....i think im going to try with at least 4" 4.5" lift overall front and rear....
jzoomer is offline
post #5 of 9 Old 03-22-2012, 07:11 PM
Motorcharge
Depends how you're stacking it and which leafs you're using.
|SOLD|
| June 2015 COTM |
post #6 of 9 Old 03-22-2012, 07:54 PM
Durt_Diver
iro 4" kit. iro adjustable track bar. currie upper and lower control arms. upper ca's can probably wait a little if need be. i would buy lowers first and see how it flexes. iro hack n tap sye. boom, thats a great lift right there
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline
post #7 of 9 Old 03-23-2012, 08:46 PM Thread Starter
jzoomer
i have i think 2-3 springs from each side (all except the flat thick one at the bottom and the main one, i did a mono leaf on it and kept the extras)
how would i go about adding them onto the jeep im sure they are much longer, and may need cut down but how do i cut them correctly to length, any way i could know the lift i would get from the before installing them so i can order the front springs and put them on at the same time...
jzoomer is offline
post #8 of 9 Old 03-23-2012, 09:47 PM
lk123
1993 XJ Cherokee
dont forget your going to need everything moded/upgraded to properly adjust to the lift afterward
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #9 of 9 Old 03-23-2012, 10:16 PM
Motorcharge
Dakota leafs are similar size and the main leaf gives you about 4"s. You won't get much from adding the other leafs.
http://www.lunghd.com/Tech_Articles/...udget_Lift.htm
That^ will do a better job of explaining what to do than I could.
Unless you're going over 4" there really isn't much you need to change outside of having an alignment done.
|SOLD|
| June 2015 COTM |
whats the biggest tires i can run ketchem23 XJ/MJ Cherokee Non-Technical Forum 16 01-28-2010 02:06 AM
Whats the biggest sized tires I can put on my rig.. DanTreE XJ Cherokee Technical Forum 8 05-22-2005 01:21 PM
Whats the biggest tire you can fit under a 3 inch lift? BeachinXJ XJ Cherokee Technical Forum 3 11-05-2003 08:37 AM
Whats the biggest size tire I can run? TB2Blazer XJ Cherokee Technical Forum 6 10-15-2003 07:59 PM
Whats the Biggest Tire you can fit on a cherokee without a lift kit? Jeep Cherokee XJ Cherokee Technical Forum 14 11-26-2002 10:38 AM
