8.25 Spline ID - JeepForum.com
post #1 of 4 Old 09-04-2008, 07:04 PM Thread Starter
jeepnatv4life
8.25 Spline ID
Is there anyway of checking the splines of the axle without pulling it out. How do I get the gear ratio with out the tag????.................. Just bought a 8.25 that was out of the jeep.
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline
post #2 of 4 Old 09-04-2008, 07:05 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
there might be a tag/sticker on the passenger side of the axle tube next to the drum with the info on it. but if it was out of a 97+ XJ its for sure 29 spline. if it was out of a 91-95 it for sure has 27 splines. 96 was the transition year, though most had 27, some had 29
1990JEEPXJ is offline
post #3 of 4 Old 09-04-2008, 07:17 PM Thread Starter
jeepnatv4life
The spot wher the tag should be is demolished..... to much mud and wash offs just checked it.Its on the passenger side tube.
'13 RZR 570
post #4 of 4 Old 09-05-2008, 12:45 AM
EricsXJ
The Post man
EricsXJ's Avatar
Don't double post in multiple sections. Since this is a tech question, your post in Cherokee Tech is all you need.
But really, this has been asked dozens of times before. You could have used the search feature. Don't know how? Here's a tutorial: http://www.albinoblacksheep.com/flash/posting
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
Closed Thread
Ford 8.8 with 28 spline shafts, is it worth it to go 31 spline? 2doorxj XJ Cherokee Technical Forum 14 11-15-2009 06:22 PM
Chrysler 8.25 27 spline to 29 spline mthomson XJ Cherokee Technical Forum 3 09-25-2009 09:34 PM
27 spline Chrysler 8.25 questions, best LSD or upgrade to 29 spline skid2964 XJ Cherokee Technical Forum 5 05-12-2007 08:52 AM
27 spline vs 29 spline stregth (searched) MPETESS10 XJ Cherokee Technical Forum 13 07-03-2006 10:44 AM
29 spline 8.25 vs 30 spline D44 vs 31 spline 8.8"? Muddy Cherokee XJ Cherokee Technical Forum 1 05-30-2006 10:43 PM
