5.9 GC Limited vs. 4.0 Cherokee - Page 2 - JeepForum.com
post #16 of 20 Old 06-24-2008, 07:37 PM
justinwalden
Originally Posted by Curt941 View Post
So 1999's have 8.25 rear ends and HP Dana 30's up front?
I guess I got some misinformation since i thought the LP dana 30 started in 1999.
Thanks guys.
it was half way thru production year of 99.
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline
post #17 of 20 Old 06-24-2008, 09:02 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Thanks guys.
'99 could have either HP or LP, depending upon how late in theyear it was made. It could also have either the 8.25 of D35, depending upon if it has ABS or not (ABS=D35).
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #18 of 20 Old 06-24-2008, 11:25 PM Thread Starter
Curt941
Yeah, the ones i've all found have ABS. I found a 1999 limited that looks good in the pictures, i'll have to check it out and see if it has the hp or lp dana 30.
Curt941 is offline
post #19 of 20 Old 06-25-2008, 07:00 AM
Power5
GC has an aluminum axle in the rear. Useless for offroad, and more prone to leaks and bearing problems. I would get it though. I like the look of the ZJ lifted more than a XJ. If you are just doing a small lift it should be fine. Just reinforce the frame at the track bar mounts and the Control Arm mounts.
Aaron
1999 XJ @ 6 on TSL 35s w/ Aussie D44 & XRC8
Power5 is offline
post #20 of 20 Old 06-25-2008, 09:14 PM
440_Magnum
Well, I came from the Mopar world first, so I think the 5.9 LA-block v8 is one of the best engines ever made. But not enough better than the 4.0 to make me want to feed one right now :-/ A 5.2 can get decent mileage, but the long stroke on a 5.9 pretty much means its stuck in the mid-teens at best.
I've gained a new respect for the 4.0/5-speed combo in my lightweight, simple, fun little 99 XJ, and wouldn't give it up for a luxo'd-up Grand Cherokee at all, 5.9, 5.2, or even a Hemi. OK, well maybe a Hemi....
Either one is a great vehicle, but if you're looking for cheap to own and operate, the XJ/4.0 combo is cheaper.
440_Magnum is offline
backfiring, 89 cherokee limited 4.0 f.rock XJ Cherokee Technical Forum 5 02-12-2008 08:50 PM
grand Cherokee wheels fit a 1993 Cherokee Limited? Spanishfly XJ Cherokee Technical Forum 9 06-09-2007 08:21 AM
cherokee limited numnuts XJ Cherokee Technical Forum 15 03-08-2007 01:51 PM
98 Cherokee Limited JBACA XJ Cherokee Technical Forum 2 04-19-2006 07:10 AM
90 Limited Cherokee psychosam73 XJ Cherokee Technical Forum 10 10-08-2002 12:26 PM
