4in lift with 31's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 4in lift with 31's?
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-02-2008, 03:29 PM   #1
fphipps
4in lift with 31's?
if i put a 4 or 4.5 inch lift on my xj would it look goofy with 31s?
if anyones got pictures of thiers with that much lift with 31s please share
thanks
RIP 99xj
fphipps is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 04:12 PM   #2
vx1kxj
no a fellow club member is running a 4 inch fabtech lift and 31s and it looks great...not to mention he got through all the areas that people with 33"s were having trouble hes bigred86 on here
00 xj clayton 3 link and yadda yadda yadda...
vx1kxj is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 06:22 PM   #3
winkosmosis
Only you can decide if it looks good
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 08:58 PM   #4
srmitchell
Eric (mod on this forum) ran the re 4.5 inch kit with 31 inch mtr's. Looked great.
I work on Mopars
srmitchell is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 09:11 PM   #5
TwistedcaB-
1991 XJ Cherokee
i personally didnt like the way it looked but then again i had trimmed fenders. looks much better with my 33's
33's
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 10:21 PM   #6
aircruiser
im running 30s on my 4.5" lift. looks goofy and i need 33s but it works for now. my avatar is my jeep with the lift and 30s.
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 09-02-2008, 10:45 PM   #7
fphipps
you would need to trim to put 33s on right?
RIP 99xj
Unread 09-02-2008, 11:10 PM   #8
TwistedcaB-
1991 XJ Cherokee
look at my pic up there ^ thats 33's with a lot of trim. but theres more clerance than you need really. you could probally do it with minimal trimming just the spots u rub when u turn and stuff nothin big
Unread 09-02-2008, 11:33 PM   #9
XJ_Austria
1994 XJ Cherokee
I find, 4" lift and 31's just look fine. Proportions and drivability are still good. Considered that with 33's you have a lot more stress to the driveline and very bad allover ratio you will have to fix alot rubbing issues. Gas mileage will also be negatively effected. 4" lift and 31's is no problem at all. If you dont want go higher than 4" and spend alot more money and hours of work, I'd forget the 33's. I have a 6" lift and 33x10,5 and still everything is close to the tyres and need a well considered bump stops and trimming.
94 Cherokee 4,0 HO 192 hp
6" RE Superflex, 33x10,5 on 7x15 Dotz Dakar 5mm offset,
TJM rear steel bumper, ConFerr 6" heavy duty Roof Rack, narrowed, 4x6 feet with 8 Hella ligths
JKS Quick-Disconnects, rear sway bar deleted
XJ_Austria is offline   Reply With Quote Quick reply to this message
Unread 09-03-2008, 04:12 AM   #10
Grinola
1986 XJ Cherokee
I am doing a 4" lift an I intend to go with 31's Do I need to alter the bumpstops?
86 Pioneer Maybe!!
Grinola is offline   Reply With Quote Quick reply to this message
Unread 09-03-2008, 05:11 AM   #11
XJ_Austria
1994 XJ Cherokee
In principle no. However no Jeep is like the other. I had a 4" OME lift with 31's and I did not need other bump stops. However, it depends on your wheels also... I have 7x15 Dotz Dakar wheels with 5mm offset. Coming out a little more. If you are running 31's on stock wheels (13mm offset) you might have rubbing at rear on the inner fender side. Same is with steering angle limiter. In case you running stock wheels with 31's you will have to limit sterring angle with wheels having less offset it will be okay.
Buit if you want to be on save side, add spacer to the bump stops same as your lift increase.
Unread 09-04-2008, 04:02 PM   #12
biggerbrowndog
Xj its up to you
i'd go for a rusty's 3 in lift
for 31"s its heck of alot cheaper
(maybe its just me being cheap)
and just looks cool
biggerbrowndog is offline   Reply With Quote Quick reply to this message
Unread 09-04-2008, 10:04 PM   #13
fphipps
yeah i would but a buddy of mine has a complete 4in(or 4.5in)with SYE and everything for $200
so ithink thats pretty cheap
only has about 5000 miles on it too
RIP 99xj
