4 wheel line lock? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 4 wheel line lock?
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 03-16-2015, 09:15 PM   #1
Xride
4 wheel line lock?
Looking to have the ability to lock all 4 wheels so that I don't have to be standing on the brakes when winching someone out, or just being an anchor point.
And CHEAP!
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 09:39 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Anchor your Jeep with a strap and shackles..
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 03-16-2015, 09:42 PM   #3
Xride
If I'm being the anchor it is generally because nothing else around is suitable.
Also less work to just lock the brakes up over getting straps out, hooking up, taking up the slack and then setting up the winch.
Unread 03-16-2015, 10:10 PM   #4
JeepN4KC
JeepN4KC's Avatar
Wheel chocks........?
I get what you're saying but sometimes you have to anchor yourself in order to be a solid anchor.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 03-16-2015, 10:12 PM   #5
Xride
Right, but like yesterday there were 4 occasions where I just needed to sit inside on my brake pedal. Happens all the time really.
I'd rather not have to sit there holding my brakes if possible.
Is there somewhere I could install a standard line lock and get all 4 wheels to lock?
Unread 03-16-2015, 10:29 PM   #6
JeepN4KC
JeepN4KC's Avatar
If there is I'd be interested as well - make for an awesome parking brake when in the mountains.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 03-16-2015, 10:35 PM   #7
Xride
That too.
I guess could just install two line locks, but that is twice as much as I want to spend, lol.
Unread 03-17-2015, 08:01 AM   #8
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That too.
Scotch blocks.
Used them on my wreckers, including a heavy duty one, for years.
http://www.awdirect.com/steel-scotch...150317140110:s
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 09:23 AM   #9
Xride
Originally Posted by cruiser54 View Post
Scotch blocks.
Still putting stress on that little tiny parking pin though.
Unread 03-17-2015, 09:43 AM   #10
IDIdiesel
Slide your seat all the way back, measure from the front of seat to the brake pedal and cut a 2x4 to that length. Stick it on the pedal and slide the seat forward. I use that trick on my diesel in the winter as a cheap high idle switch
1991 Ford F250 7.3L IDI diesel
2001 Cherokee sport "AGENT ORANGE"-DD BUILD THREAD: http://www.jeepforum.com/forum/f177/agent-orange-build-1306755/
1948 Willys CJ2A++1994 Wrangler 4cyl. manual trans++2012 JK 4dr unlimited 6spd
IDIdiesel is offline   Reply With Quote Quick reply to this message
Unread 03-17-2015, 09:57 AM   #11
Xride
I was thinking a high tech stick. Wasn't sure it if it would be hard on the booster or not though.
I don't mind spending money, but didn't want to spend 200 bucks to get two line lock kits, was hoping there was a way to get away with just one line lock kit.
Unread 03-17-2015, 01:41 PM   #12
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No, you're not if you use them properly. You winch yourself up on to them with the chains looped correctly so the centerline of your axle is over the digging part of the block. More pull and the block bites more and more.
Unread 03-17-2015, 01:50 PM   #13
ravenworks
ravenworks's Avatar
I made a set of spades for our heavy wrecker but you need a jockstrap to lift them.
Semper-Fi "81-84"
"People Died and Clinton Lied"
Benghazi
I.U.O.E. - 18
ravenworks is online now   Reply With Quote Quick reply to this message
Unread 03-17-2015, 01:55 PM   #14
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Mine were so heavy that I made a place down low to store them!!
1/2 inch Grade 80 chain. Old Holmes 750....
Unread 03-17-2015, 04:21 PM   #15
Xride
I see what you are saying. Still more setup than pushing a button though, even though it would probably be better.
