4:88's? Yay or nay? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 4:88's? Yay or nay?
Unread 04-28-2013, 02:31 AM   #1
amatotime
4:88's? Yay or nay?
I'm able to pick up a set of 4:88's for a Dana 30 front and Dana 44 rear. I'm currently running 3:55s with 35" tires. It does pretty decent but I can pick up the gears for 275$ brand new and am if it's worth spending the money to get them?
amatotime is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 08:18 AM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Are the gears used?
Also - might need a new carrier for the D30 gears.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 09:51 AM   #3
RedRyderXJ
1994 XJ Cherokee
Originally Posted by JeepN4KC
Are the gears used?
It literally says they're new... Lol.
Yes you will need gears, master install kits, and a new D30 and D44 carriers because of the carrier break.
I say that's a good deal. You could use thick cut gears so you don't have to get a new carrier. And also make sure they are the correct cut pattern for your axles.
RedRyderXJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 10:01 AM   #4
1990JEEPXJ
1990 XJ Cherokee
That's an ok deal. Not the best. But I'd say go for it
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 11:44 AM   #5
amatotime
Ok thanks for the help, I didn't know know I was going to need new carriers and all that.haha I've never messed with the gears.
Unread 04-28-2013, 11:54 AM   #6
RedRyderXJ
1994 XJ Cherokee
You have a 99 so you will need:
Reverse cut gears for your 99 (assuming its HP)
New carrier for the D30
New gears or thick cut for the D44
New carrier if gears arent thick cut
Master install kits and someone to set the gears up correctly.
Unread 04-28-2013, 02:18 PM   #7
amatotime
The gears are thick cut, the Dana 30 I have in the front is off a 96.
Unread 04-28-2013, 02:26 PM   #8
1990JEEPXJ
1990 XJ Cherokee
That doesn't mean thick cut. Thick reverse cut gears for the 30 are nearly non existent anymore. They weren't a factory item on these
My POS
Unread 04-28-2013, 02:33 PM   #9
amatotime
I'm saying that the 4:88s I'm trying to get are thick cut
Unread 04-28-2013, 04:52 PM   #10
RedRyderXJ
1994 XJ Cherokee
And he is saying that for the D30, typically you HAVE to get a new carrier instead of using reverse cut thick gears, because of the break in them.
I would also be surprised if the D30 gears are thick reverse cut. Find the numbers tamped on them.
Unread 04-28-2013, 04:54 PM   #11
amatotime
Ok I see now, I will look at the numbers
Unread 04-28-2013, 04:56 PM   #12
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Most 99 XJ's have 8.25 rear axles you may want to make sure you have a 8.25 cause D44 gears wont work in it !
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 05:06 PM   #13
amatotime
It's a Dana 44 I promise.haha I'm familiar with all the axels.
