4:88's? Yay or nay? - JeepForum.com
post #1 of 13 Old 04-28-2013, 01:31 AM Thread Starter
amatotime
4:88's? Yay or nay?
I'm able to pick up a set of 4:88's for a Dana 30 front and Dana 44 rear. I'm currently running 3:55s with 35" tires. It does pretty decent but I can pick up the gears for 275$ brand new and am if it's worth spending the money to get them?
amatotime is offline
post #2 of 13 Old 04-28-2013, 07:18 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Are the gears used?
Also - might need a new carrier for the D30 gears.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 13 Old 04-28-2013, 08:51 AM
RedRyderXJ
1994 XJ Cherokee
Originally Posted by JeepN4KC
Are the gears used?
It literally says they're new... Lol.
Yes you will need gears, master install kits, and a new D30 and D44 carriers because of the carrier break.
I say that's a good deal. You could use thick cut gears so you don't have to get a new carrier. And also make sure they are the correct cut pattern for your axles.
RedRyderXJ is offline
post #4 of 13 Old 04-28-2013, 09:01 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
That's an ok deal. Not the best. But I'd say go for it
1990JEEPXJ is offline
post #5 of 13 Old 04-28-2013, 10:44 AM Thread Starter
amatotime
Ok thanks for the help, I didn't know know I was going to need new carriers and all that.haha I've never messed with the gears.
post #6 of 13 Old 04-28-2013, 10:54 AM
RedRyderXJ
1994 XJ Cherokee
You have a 99 so you will need:
Reverse cut gears for your 99 (assuming its HP)
New carrier for the D30
New gears or thick cut for the D44
New carrier if gears arent thick cut
Master install kits and someone to set the gears up correctly.
post #7 of 13 Old 04-28-2013, 01:18 PM Thread Starter
amatotime
The gears are thick cut, the Dana 30 I have in the front is off a 96.
post #8 of 13 Old 04-28-2013, 01:26 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
That doesn't mean thick cut. Thick reverse cut gears for the 30 are nearly non existent anymore. They weren't a factory item on these
post #9 of 13 Old 04-28-2013, 01:33 PM Thread Starter
amatotime
I'm saying that the 4:88s I'm trying to get are thick cut
post #10 of 13 Old 04-28-2013, 03:52 PM
RedRyderXJ
1994 XJ Cherokee
And he is saying that for the D30, typically you HAVE to get a new carrier instead of using reverse cut thick gears, because of the break in them.
I would also be surprised if the D30 gears are thick reverse cut. Find the numbers tamped on them.
post #11 of 13 Old 04-28-2013, 03:54 PM Thread Starter
amatotime
Ok I see now, I will look at the numbers
post #12 of 13 Old 04-28-2013, 03:56 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Most 99 XJ's have 8.25 rear axles you may want to make sure you have a 8.25 cause D44 gears wont work in it !
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 13 Old 04-28-2013, 04:06 PM Thread Starter
amatotime
It's a Dana 44 I promise.haha I'm familiar with all the axels.
