4.5" Lift Bilstein shock length - JeepForum.com
post #1 of 6 Old 06-03-2012, 01:04 AM Thread Starter
k4ylr
Got a quick question for you suspension gurus. I'm looking at putting the RE 4.5" SuperFlex kit onto my XJ and I'll be building them around Bilstein 5100s.
The only sizes I've seen are for 4" and 5" of lift. So my question is it better to get the 1//2" shorter to serve as a pseudo limiting strap or go a 1/2" longer to have some breathing room in terms of travel?
I don't do huge rock crawling or trails that call for ridiculous amounts of flex.
'ppreciate it!
k4ylr is offline
post #2 of 6 Old 06-03-2012, 01:44 AM
ltrail
1984 XJ Cherokee
Depends on compressed and extended lengths I guess. Using them as limitation of down travel seems to be less damaging than the stop for uptravel.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 6 Old 06-03-2012, 08:01 AM
rugsucka
Go for the longer shock and use correct bumpstops to limit uptravel - you may not think you need the flex now, but you will like the droop for travel whether you do rocks or run across the desert.
If you're putting a set of 33-35" tires to suit the lift, you'll run out of fender clearance before you bottom out the shocks unless you trim super aggressively.
rugsucka is offline
post #4 of 6 Old 06-03-2012, 08:08 AM
jeepinmichguy_
Get your suspension on the Cherokee and put it at full bump (make sure there are no clearance issues). Then measure compressed lengths, flex and measure the extended lengths, order shocks.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #5 of 6 Old 06-04-2012, 05:18 AM Thread Starter
k4ylr
I'm shooting for 32's or 33's (regearing kind of makes my shy away from 33s) since the GT Kevlars are similarly priced in that ballpark. Eventually I'll move up to flat flares so I'm leaning towards 33's to fill out the wheel wells. Thanks for the tips guys.
k4ylr is offline
post #6 of 6 Old 06-04-2012, 07:51 AM
dcorn
Whoops, wrong thread.
2014 Jeep Grand Cherokee Summit
dcorn is offline
What length shock for a 6'' lift? bravojmc XJ Cherokee Technical Forum 2 04-19-2011 01:35 PM
Bilstein Jeep Cherokee 4" Shock Specs trailwerks XJ Cherokee Technical Forum 4 07-30-2009 12:30 AM
Shock length 3"-3.5" lift? VR6NH XJ Cherokee Technical Forum 2 04-06-2009 02:35 PM
Recommended Shock Length for 2" Lift Whtfairladyz XJ Cherokee Technical Forum 5 03-04-2009 07:04 PM
Shock length for 5" rear lift? Compressed and extended broncofire75 XJ Cherokee Technical Forum 5 08-11-2008 05:33 PM
