4.5" lift and 33's Flex shots - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 4.5" lift and 33's Flex shots
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-14-2008, 08:09 PM   #1
TwistedcaB-
1991 XJ Cherokee
got bored today after doing some PITA work on my TPS sensor. 5 min. job turned into a 4 hour job after a bolt broke that no shops had.
but anyways here are the shots. and also is it common to have more flex backwards than forwards?
the only rub
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline   Reply With Quote Quick reply to this message
Unread 07-14-2008, 08:19 PM   #2
toaster
1993 XJ Cherokee
you know, just today i decided to take a look around and see what a 4.5 lift and 33s looked like and this is the first thread i saw. thank you. i get to take my jeep back from the wife next month and thats exactly what im gonna do first.
ps. this is also my first post.
toaster is offline   Reply With Quote Quick reply to this message
Unread 07-14-2008, 08:23 PM   #3
TwistedcaB-
1991 XJ Cherokee
haha well im glad i could do some good today. and it's a Rustys 4.5 w/ a full spring pack
Unread 07-14-2008, 10:13 PM   #4
XJohnnyC
Well, at least you got half-way off the pavement.
XJohnnyC is offline   Reply With Quote Quick reply to this message
Unread 07-14-2008, 10:29 PM   #5
TwistedcaB-
1991 XJ Cherokee
haha i was tryin. all the trails are all an Hour+ away so i don't really get to go out mostly just messin around in the riverbed and small trails, hill climbs and stuff
Unread 07-15-2008, 01:07 AM   #6
broncofire75
I think the more backwards flex comes when the front is doing more drooping with the force of the flex on the rear. I'm going to have to try it never have but you see in pics all the time how far the front tires will droop and flex when its backed up to a hill or ramp.
P.s. I like the Kumho sticker with the Baja Claws LOL.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2008, 01:46 AM   #7
TwistedcaB-
1991 XJ Cherokee
haha those are from my old tires and there a PITA to get off
Unread 07-17-2008, 08:17 PM   #8
nootay
looks good man! just curious what bolt you broke? i screwed up the threads on a castle nut the other day and couldnt find anyone around that had one of those
99 XJ Sport, Rubicon Express 3.5" Super Flex, JKS adjustable track bar, 15x8 chrome cragar soft 8's, 32x11.50 BFG AT, OME Nitro Charger Shocks, hacked front fenders
nootay is offline   Reply With Quote Quick reply to this message
Unread 07-18-2008, 12:41 AM   #9
TwistedcaB-
1991 XJ Cherokee
thanks man, it was one of the TINY bolts that holds the CPS in place, i was adjusting it cause my jeep was acting weird and went i went to tighten it it just snapped.
Unread 07-19-2008, 02:04 AM   #10
MiNiBeast
1989 MJ Comanche
Also has to do with having stock CA still on there.
MiNiBeast is offline   Reply With Quote Quick reply to this message
Unread 07-19-2008, 04:45 AM   #11
TwistedcaB-
1991 XJ Cherokee
im assuming you mean the upper control arms, cause the bottoms are the Bent ( for max clearance on mounts) Rustys arms.
Unread 07-20-2008, 03:57 AM   #12
MiNiBeast
1989 MJ Comanche
HUh, no. I mean you need some adjustable arms atleast lower one, or perhaps some drop brackets. High Clearence arms don't mean crap if you are still runing stock length at a 4.5" lift height. Your geomentry is out of balence, being why you do not get all that great of flex in which you could be getting better.
Unread 07-20-2008, 04:04 AM   #13
TwistedcaB-
1991 XJ Cherokee
there not stock length. there longer and are the ones for the kit. but either way im getting a front Rustys 6.5 W/ adjustable arms sometime in not too long hopefully. but if the arms were any longer i would have some trouble seeing how they allready rub the front of my fender.
Unread 07-21-2008, 04:17 AM   #14
MiNiBeast
1989 MJ Comanche
Which is why you should get some long arms or drop brackets. Which what gives you a better approach angle for your tires when hitting bumps and climbing rocks, thus a smoother ride as well. It allows you axle to go up and down, as if up over bumps and rocks, without putting access stress on your mounts. Which right now their going more straight toward an object thus having more of a right at the object impact, instead of a smooth ride over a object.
Check this thread out...
http://www.naxja.org/forum/showthread.php?t=956210
Unread 07-21-2008, 05:48 AM   #15
TwistedcaB-
1991 XJ Cherokee
yeah i've taken a look at those before just got to get some more money goin.
