4.5 inches on 31's looks dumb. ideas? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 4.5 inches on 31's looks dumb. ideas?
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 07-26-2011, 06:21 PM   #1
Brookhart63
Hey I just lifted my Jeep to 4.5. Now my tires look way to small and I was wondering what it would look like on 33 1250's on 10 inch wide wagon wheels. How much trimming would be needed? I would assume that I would have to trim more since the wider tire with more backspace. Would 15x8 on 33 12.50 look better? Mainly for looks and to get my tire away from leaf springs. I'm re-gearing when I get a 8.8 in.
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2011, 07:17 PM   #2
Kettles
I run 235's on 3-4" lift and I like the look, so 31's on 4.5" can't be too bad.
But, I think a 10" wide wheel is WAY to wide (visually) for anything near that small. 15x8 would be better.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
The Rocket Sheep
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote Quick reply to this message
Unread 07-26-2011, 08:17 PM   #3
Brookhart63
So maybe i should just get 15x8's? wouldnt that make the tire shorter?
Bought not Built
Unread 07-26-2011, 08:36 PM   #4
Brookhart63
So i like the way it looks from the side.... not to mention it flexes like a champ, but the back looks like it will tip over.
Bought not Built
Unread 07-26-2011, 08:37 PM   #5
Kettles
15x8s will reduce the overall width, and it will hold the bead better when aired down than a 10" wide tire. The Tire will be exactly the same diameter regardless of the wheel, as that is dictated by steel belting that constructs the tire, it cant get bigger or smaller (it can bulge and flex the sidewalls, but the tread surface doesn't change unless its super overinflated and even then it would barely increase the size).
_=====o000o
The Rocket Sheep
Unread 07-26-2011, 08:41 PM   #6
Kettles
I think it looks great, the wider stance you want can be accomplished with different backspacing or wheel spacers. I personally don't like the tires sticking out past the flares much. 12.50, on a 10" wheel, with around 4" of BS (likely what you would get) would stick out a good bit more than my preference. And if your trimming, your likely going to be removing the flares which will make it look wider as well.
For aesthetics its of course all personal opinion, I only know what I like, I can't tell you want you like. If I was looking for a 32 or 33" tire, I would run on a 7 or 8" wide rim with 4-4.25" BS to keep it tucked in, or else get some bushwacker flat flares to cover the tires on a 3.75-4" BS 8" wheel. But I like my tires covered.
I have been known to have very specific tastes as well, so I may not be the best person to encourage you, .
_=====o000o
The Rocket Sheep
Unread 07-26-2011, 08:45 PM   #7
alexrule123
When I was at 4" of lift this is what 32x10.50 looked like, when I went to 6" they look tiny.
@4"
@6"
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2011, 09:18 PM   #8
Brookhart63
Well i might have to go with kettles. I like they way it looks from the side i just want different backspacing for my rims. The 32's look beef on 4 inches though... i almost like they way 32's look with 6 than 4
Bought not Built
Unread 07-26-2011, 09:28 PM   #9
Kettles
Agreed With the stock fenders it looks better with 6".
_=====o000o
The Rocket Sheep
Unread 07-29-2011, 06:16 PM   #10
BlakeDGKleavitt
1997 XJ Cherokee
How much back spacing could I do or how would I I'm getting a 3" lift and I have stock rims 15" and 30" tires.
BlakeDGKleavitt is offline   Reply With Quote Quick reply to this message
Unread 07-29-2011, 06:18 PM   #11
BlakeDGKleavitt
1997 XJ Cherokee
Dood I'd keep it just like that it's friggen cool. That color is awesome too.
Unread 07-30-2011, 09:05 AM   #12
cbenez1
I think it looks fine but you should put some attention into the lca's. Your frt axle is sitting back a tad to much. I would invest in some extended or adjustable lca's before doing anything else.
cbenez1 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2011, 10:23 AM   #13
Luke94XJ
1994 XJ Cherokee
I'd do the 15x8s 15x10s look a little weird with 12.50 tires. also your rims are sticking out there to catch on rocks and tree stumps, and you get a little more side lug with the narrower wheels.
mine on ~5" with 33s
Luke94XJ is offline   Reply With Quote Quick reply to this message
Unread 07-30-2011, 11:03 AM   #14
Brookhart63
Yeah i see this. Ill either extend these or just wait a year till i go full widths.
Bought not Built
Unread 07-30-2011, 11:30 AM   #15
GregB_00XJ
I think it looks good with the 31" on it. I do however agree that it looks a little tippy. lol I bought a set of Soft 8 wheels off of JC Whitney with 3.75" BS (15 x 8) and really like they way they look with 31" tires. They do however hit the stock flares if you aren't careful with the bump stops. Almost did some impromptu trail body work that way once.
4" or 4.25" BS on a 15 x 8 would be ideal.
2000 Jeep Cherokee Classic XJ - 2005 Jeep Grand Cherokee LTD 5.7L WK - CDN M101 1/4 Ton Trailer
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote Quick reply to this message
