33x13.50 or 34x10.50 ltb - JeepForum.com
post #1 of 7 Old 06-26-2008, 12:38 PM Thread Starter
santosdv
which of these tires, do you guys think would work better on sand???? I own 91 xj with a 4 inch lift...... which do you recomend?
santosdv is offline
post #2 of 7 Old 06-26-2008, 12:43 PM
camjeep3
1988 MJ Comanche
you want the wide tires to keep the traction in the sand. if you air them down then you will have a really nice footprint
edit: also you may want to trim a little with a 4" lift or bumpstop maybe both
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline
post #3 of 7 Old 06-27-2008, 12:38 AM
TwistedcaB-
1991 XJ Cherokee
33x13.5's.. i want those haha
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline
post #4 of 7 Old 07-01-2008, 11:48 AM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
I like my 33x13.5 ltb's more than my 35x12.5 bfg's. Never tried the 34x10.5, thats a little skinny for my liking.
There is a rumor that Interco is already or will soon make ltb's in a 35x12.5. If this is true I want a set for the next snow-wheeling season.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #5 of 7 Old 07-01-2008, 01:02 PM
lhp21
I'd go for the wider ones. Snowshoe effect - more surface area means less weight per square inch on the sand, hence you stay up. You don't want to dig to the bottom like you might in mud with skinny tires.
lhp21 is offline
post #6 of 7 Old 07-01-2008, 01:46 PM
conrasm
conrasm's Avatar
I have the 34 x 10.50 LTB's and they are a little skinny. I'd say go with the wider tires for sand.
They are a little rough on the road with the big lugs and bias ply (flat spot that lasts for a few miles until they heat up), but I love them off road. I do mostly trails with some rocks and occassional mud.
They can be difficult to balance though.
I have 4.5" RE lift with extra coil spacer in front and trimmed with bumpstops in front. I have no rubbing at all. I also have 4" BS rims. You'll need to do some work so they won't rub.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #7 of 7 Old 07-02-2008, 01:18 AM
TwistedcaB-
1991 XJ Cherokee
i've heard differnet things about the LTB's how well do they wear? and how long do you guys usually get out of em?
33x13.50 or 35x12.50 svtknight MJ Comanche Technical Forum 10 06-19-2009 09:33 AM
Spacers for 33x13.5x15 Magus2727 XJ Cherokee Technical Forum 6 06-07-2008 11:57 PM
Debate: LTB 34x10.50x15 -v- MT/R 305/70/16 DreamsOfMoab XJ Cherokee Technical Forum 11 04-12-2006 10:27 AM
Bushwackers and 34x10.50 super swampers andrew2516 XJ Cherokee Technical Forum 26 02-19-2006 07:14 AM
34x10.50 on stock rim? NJ82TJ XJ Cherokee Technical Forum 9 01-20-2005 10:02 PM
