32s and 3.55 gears? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 32s and 3.55 gears?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 04-02-2015, 09:48 AM   #1
xjowner10
32s and 3.55 gears?
I've got an 01 l6 4.0 with a cold air intake. I'm in need of new tires and was wondering how much power I would lose if I run 32s with the stock 3.55 gears. I have an automatic if that makes any difference. I do a bit of off roading and mudding during the summer so would my power off road suffer? Also I'm not too worried about my gas mileage. Thanks
xjowner10 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 10:46 AM   #2
sAe23
1995 XJ Cherokee
I went to 33x10.50s and for ME, here in SoCal, it was annoying with 3.55 gears.
On flat roads it was ...ok... but on a road with any amount of incline, the engine started to bog and the transmission couldn't decide what gear to be in.
I upgraded to 4.56, and while it is better, I kinda wish I went to 4.88 or higher (but the cost would have been prohibitive).
HTH
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 12:25 PM   #3
xjowner10
Thanks! I might stick with 30s or possibly go to 31s
Unread 04-02-2015, 03:34 PM   #4
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
Unless you drive on the highway a lot or live in mountains its fine. It just feels like a stock 4 cyl and you throttle a little more uphill.
If you have an older XJ with the power/comfort switch for the trans it helps a lot.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 04:26 PM   #5
DunmerBoy
Desert Explorer
DunmerBoy's Avatar
i have 3.55s and 33x10.5s and only really ever noticed going uphill on the interstate, with about 800 pounds of junk and a tiure on the roof
COTM October 2014
- Build Thread -
DunmerBoy is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 07:37 PM   #6
cruechief
I run 32s with stock gears and automatic and doesn't bother me.
97 TJ 4" RC 33" baja claws
98 XJ 4 1/2 RE on 32" bfg ats
04 WJ limited 4.7 v8 Wifey's DD
cruechief is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 10:27 PM   #7
S8NNG8
1995 XJ Cherokee
We'll see how 3.55's do for 32's with a 5spd when I get my 8.25 installed. For those of you that think 3.55's suffer, try 3.07's.
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 07:08 AM   #8
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
If your gonna run 32's and 355 better make sure you have a trans cooler installed because you are running higher rpms and will heat up the tranny uphill. Been in that situation more than once.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 09:29 AM   #9
xjowner10
What tires would you guys recommend? I've been looking at a couple like bfg and mud claw. Any other recommendations? This is my dd so nothing that's got horrible tread life
Unread 04-03-2015, 09:33 AM   #10
Finallyajeep
I have 32'' cooper STT's that I like alot, also have 3.55 gears with the auto trans. Like many have said, I don't mind it around town, but once you get on the highway where there are any hills it gets somewhat annoying. Usually I just manually shift into 3rd gear for hills on the highway to keep it from searching for a gear.
Firefighters Jeep Club
Finallyajeep is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 12:49 PM   #11
Motorcharge
Bandeded
1991 MJ Comanche
I have zero issues with it. Even steady uphill at 55 I only run about 2200 RPM. Normal driving isn't much over 1500. Though that's with the trans switched to Power. Comfort is a bit higher at higher speeds.
Wrangler MT/Rs. Can't beat em off road, they're hard as hell to puncture due to the Kevlar, they have excellent road manners including in heavy rain and snow, and they wear pretty decent.
Unread 04-03-2015, 12:58 PM   #12
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Had no issues at all with 32's and 3.55s. There's powerloss over say, 225's, but it stills pulled 32s just fine. Its a Jeep not a racecar.
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 12:59 PM   #13
DunmerBoy
Desert Explorer
DunmerBoy's Avatar
this is from a guy running 35s on 3.55s haha
COTM October 2014
- Build Thread -
Unread 04-03-2015, 01:09 PM   #14
Motorcharge
Bandeded
1991 MJ Comanche
And I drive mine like one regardless. If it was bad I'd be the last person around here to tell someone otherwise.
Unread 04-03-2015, 02:51 PM   #15
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Haha exactly. Granted I also have a daily, so its kind of a non issue 4 low has plenty of power and since I dont even have to hit pavement to wheel, Im not too concerned about gearing. If anything the extra wheelspeed is nice.
You mfer's need to own a 2.5 Jeep at some point in your life and see if you ever complain about 4.0 power on 3.55s again.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
