32" tires on 2" lift - JeepForum.com
post #1 of 35 Old 11-12-2014, 01:50 PM Thread Starter
BlackXJ98
Hey guys new to the site and to lifting my cherokee. I bought a teraflex 2" spacer lift and a 2.5" RE full length add a leaf for my jeep.
I have been looking at 31s and this jeep will not be doing much off roading at all, mainly a DD. I saw some cheaper MTs by cooper that are 32x11.5 however the actual measurements are 31.3". Most marketed 31s measure actually around 30.5" - 30.8" which would make the 32" coopers only about 1/2" larger. Will these work ok on my jeep since flexing wont really be typically done? They will be mounted on 15" jegs baja 8s with 3.75" BS.
BlackXJ98 is offline
post #2 of 35 Old 11-12-2014, 01:53 PM
Luke95
It will be fine, Trim to fit.
35x12.5 on 2.5-3
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #3 of 35 Old 11-12-2014, 02:14 PM Thread Starter
BlackXJ98
Only thing is i dont want to trim. I dont mind removing the front bumper end caps. The jeep is a DD and will not see any offroad at the moment. Just some snow etc. So flexing will not be in the cards. Just typical street use for the time being.
post #4 of 35 Old 11-12-2014, 03:33 PM
Luke95
Originally Posted by blackxj98
only thing is i dont want to trim. I dont mind removing the front bumper end caps. The jeep is a dd and will not see any offroad at the moment. Just some snow etc. So flexing will not be in the cards. Just typical street use for the time being.
nope.
Luke95 is offline
post #5 of 35 Old 11-12-2014, 04:17 PM
1stockjeep
1993 XJ Cherokee
First driveway you hit the tires will hit the front flares and chew up fender
1stockjeep is offline
post #6 of 35 Old 11-12-2014, 05:29 PM
sAe23
1995 XJ Cherokee
Well, he *could* bump stop it to all heck so it doesn't hit the fenders
sAe23 is offline
post #7 of 35 Old 11-12-2014, 05:34 PM
rugsucka
No up travel suspension would be a very comfortable ride.
Trim or GTFO would be my suggestion.
rugsucka is offline
post #8 of 35 Old 11-12-2014, 05:43 PM
sAe23
1995 XJ Cherokee
[Homer Simpson voice in a loud whisper]: I wasn't being serious; That's why I used the sarcasm smiley.
sAe23 is offline
post #9 of 35 Old 11-12-2014, 07:04 PM Thread Starter
BlackXJ98
Well I def know 32s without trimming on 2" would be tough. The only reason I'm considering is because the actual diameter of say the big km2 "31s" is 30.8" where as the actual size of the cooper mud claw "32" is 31.3" which the diff ends up being only .5" in the actual reality. Or 1/4" top and bottom of the tire. I see a lot of guys running 31s on a 2" lift without trimming. They may not have much flex but as I said this is a DD that will see snow at best.
post #10 of 35 Old 11-12-2014, 08:30 PM
sweryap
I had trouble with 31's rubbing on a 2" boost, ended up moving to 30's. Others seem to have had different experiences, but 32's seem really unlikely to work to me.
sweryap is offline
post #11 of 35 Old 11-12-2014, 08:44 PM
rugsucka
Had to trim a 2" BB and 31" MTR combo to disconnect and wheel. Needed 4" BS wheels to turn full lock as well.
Would have trimmed if I left it a mall crawler too. Small wheel wells originally designed for 28" tires.
rugsucka is offline
post #12 of 35 Old 11-12-2014, 09:03 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
If you're only gonna drive it on the street I'd imagine it'll be fine.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #13 of 35 Old 11-13-2014, 05:54 AM
Iceman12
Something your not taking into consideration with your tire measurements. Width. You are only comparing hieghts. The larger tire is an inch wider. It's not the middle of the tire that will grab the fenders. It won't rub in a straight line, it's in a turn with the tires on a 45 degree angle to the fender where those edges with grab hold of the bottom corners of the fenders. They will rub. I had to do slight corner trimming with 3" of lift and a 31x 10.50 . Had the same back spacing rim as you are going to use as well. Some get lucky with 31's not rubbing. I don't see it happening with out trimming for the 32x11.50's.
Iceman12 is offline
post #14 of 35 Old 11-14-2014, 07:10 AM Thread Starter
BlackXJ98
well i appreciate all of the help/input from everyone. Another question is if i was to follow the bushwacker install instructions with regards to trimming and relocate the stock fenders would that help fit these tires for DD use? I am able to get a good deal on them so thats why I am looking into it. Other than that i may just end up having to go with the 31s. At the end of the day with these particular "32s" I only need to fit about .5" extra in diameter and .7" in width from you standard 31s.
post #15 of 35 Old 11-14-2014, 09:05 AM
DunmerBoy
The bushwhackers might do it for ya. Somewhere I saw a build for a mall crawler on 33s and 2 inches of lift with them. I would still extend your
Bump stops. Easy to do.
COTM October 2014
DunmerBoy is offline
