31" vs 32" - JeepForum.com
post #1 of 12 Old 09-05-2012, 11:36 PM Thread Starter
Steelo805
31" vs 32"
Is there a noticeable difference driving on 31/10.5/r15 vs 32/11.5/r15 on 3:55 gears? The tires will be BFG TA/KOs
I do know how to use the search feature, jus couldnt find the info i wanted
Steelo805 is offline
post #2 of 12 Old 09-06-2012, 01:39 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It's about a 3% difference. Tires can wear that much over their lifespan.
I don't think you'll notice much difference with respect to the gearing.
***Chris***
chris87xj is online now
post #3 of 12 Old 09-06-2012, 06:08 PM Thread Starter
Steelo805
Thanks and yeah that makes since but I'd also have to factor in the extra inch width..
post #4 of 12 Old 09-06-2012, 08:00 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I'm running 31x10.5x15 w/stock backspaced rims and stock control arms on my 96 DD xj, so know exactly what you're working with there and am fine with that small loss of turning radius but am thinking an extra inch of width might take it a bothersome state.
***Chris***
post #5 of 12 Old 09-06-2012, 08:10 PM Thread Starter
Steelo805
How's the power?
post #6 of 12 Old 09-06-2012, 08:14 PM
skip11and1
2013 MK Patriot
i ran steelies and 31/10.5 and then alloys and 32/11.5 and got better mpg on my old cherooke. 1.5 mpg every fill up more, I think the weight of the rims have more of a impact of the vehicle then tire size as long as your not comparing 31 vs 38 then obv the 31 will be better for vehicle performance
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #7 of 12 Old 09-06-2012, 08:36 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Originally Posted by Steelo805 View Post
How's the power?
Fine by me, not that much difference than it was stock.
I'm no dragster but I wanna be able to pass when I need to. Also use it to tow an ATV trailer or small boat at times. No complaints.
***Chris***
post #8 of 12 Old 09-08-2012, 10:34 PM Thread Starter
Steelo805
So you wouldn't suggest 32s on some summit racing 15" steelies
post #9 of 12 Old 09-09-2012, 07:42 AM
NJXJ91
31x10.5 is the max usually on 3.55's
NJXJ91 is offline
post #10 of 12 Old 09-09-2012, 08:24 AM
Motorcharge
There's no real noticeable difference. It's not even much different than 235s other than at idle. I don't idle forward as much and I don't at all up minor grades. Takes a little *** to move from a stop, but not much and after that I don't notice any difference. I wouldn't hesitate to run 32s on 3.55s again.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #11 of 12 Old 09-09-2012, 09:23 AM
kenC
32's on stock gears sucks imo,it wont tow for crap and with a/c on in the summer it barely wants to climb the hills,i put 4,10 gears in and im glad i did.if u live on flat ground and dont tow much u would probably be ok i would definetly get a upgraded trans cooler
kenC is offline
post #12 of 12 Old 09-12-2012, 06:18 PM
skip11and1
2013 MK Patriot
i dont think 32's would be that much of a noticeable difference then 31's in daily drving. the only time you may notice it is trying to hold highway speeds on hills
"feathering" or "hissing" noise from engine? johnlocke XJ Cherokee Technical Forum 3 02-17-2011 12:42 AM
98 XJ, "needs oil pressure sensor", and "CEL is on for generic trans code's" Grip XJ Cherokee Technical Forum 9 12-13-2009 07:51 PM
Local JY question... "A Deal" or "A Hole" Fletch8672 XJ/MJ Cherokee Non-Technical Forum 6 12-10-2009 06:10 PM
Turn signals "on", when drive lights "on" R5ROD XJ Cherokee Technical Forum 3 07-07-2008 03:22 PM
Driver side door "popping", need new restraining "bracket"? 19OlllllllO41 XJ Cherokee Technical Forum 16 10-02-2007 11:08 AM
