$300 '92 Beater Build - Page 104 - JeepForum.com
post #1546 of 2210 Old 11-20-2012, 08:07 AM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
Originally Posted by No4x4Yet View Post
Those shock work like that? They look extremely flat.
No clue, but for right now it is either have them like that or just have them hanging. If that is at too much of an angle (flat) then I'll have to get the new shock mounts welded on.
koolaid5 is offline
post #1547 of 2210 Old 11-20-2012, 09:23 AM
my1979impala
Ahh i see. Im plannin to cut a hole in the floor and run my shocks up to my roll cage inside and didnt know if there was some benefit to mounting them on an angle like yours.
jeepforum.com/forum/f176/2000-tj-build-2269009
my1979impala is offline
post #1548 of 2210 Old 11-20-2012, 10:01 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Not that I'm aware of. I'm sure I'm either going to have to go up through the floor with mine if I keep the lower mounts where I have them. I'm more than likely going to weld new lower shock mounts on the axle tube though. I'll be able to cut down on how much of an angle the shocks are at now.
koolaid5 is offline
post #1549 of 2210 Old 11-20-2012, 10:12 AM
GetLifted
The thrust angle on the shock makes it completely usess. I'd remove em before you bend a shock shaft...or worse.
GetLifted is offline
post #1550 of 2210 Old 11-20-2012, 10:14 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Originally Posted by GetLifted
The thrust angle kn the shock....its completely usess. I'd remove em before you bend a shock shaft...or worse.
Thanks for the info, but no worries there man. . . This thing is just sitting in the garage and the lower shock mounts are just resting there. I don't have bolts to attach them if I wanted to.
koolaid5 is offline
post #1551 of 2210 Old 11-26-2012, 11:24 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Not much, but any forward progress is good, right? I picked up this used gas tank skid probably about 2 years ago now. Just going to clean it up a bit and spray it with some rattle can bedliner. While paint is drying I think I'll finally work on centering the front axle since I just slapped it under there all wonky real quick, so I could get it trailered to PA.
koolaid5 is offline
post #1552 of 2210 Old 11-26-2012, 08:32 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Didn't get to thefront axle, but I got the gas tank skid and my sliders all prepped for paint. Might be too busy playing with the kids in the snow tomorrow to get anything done and right now I'm laying here hooked up to a ton of wires for my sleep study. Fun stuff
koolaid5 is offline
post #1553 of 2210 Old 12-02-2012, 10:37 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Got the gas tank skid and T&T sliders all prepped, but then had to work the past 4 days, so that's all the further I got. I have the next day and a half off, so after I put up the xmas lights, before the wife kills me, I'll see if I can't get some more odds and ends prepped/painted and possibly even installed.
koolaid5 is offline
post #1554 of 2210 Old 12-02-2012, 08:08 PM
ProdigyXJ
love this thread man... just arranged a deal on a 2000 XJ for 100$ this past week and have been reading through this thread bit by bit!
pick mine up next sunday can't wait to get crackin on it...
part of why i got mine for only 100$ is no tires/rims. already snagged today some older aluminum ones off kijiji (like CL) for 20$ each today... hoping to do something similar with mine we'll see how far it goes... got an 86 F150 i may strip for some parts like the 8.8" with a ford racing LSD in the back...
ProdigyXJ is offline
post #1555 of 2210 Old 12-02-2012, 08:15 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Outstanding! Sounds great. Keep me updated on the progress. Where are you located?
koolaid5 is offline
post #1556 of 2210 Old 12-02-2012, 08:24 PM
ProdigyXJ
Kitchnener/Waterloo Ontario.... home of those pesky blackberrys...
thinkin only a 3" lift (290$ @ http://www.national4wdonline.com/car...ategory_id=363 which is near by) since it'll let me run my BFG Allterrain TA 31's
hoping to keep it cheap... but we all know that never works out..
post #1557 of 2210 Old 12-02-2012, 08:28 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Not a bad deal there. . . Have fun with that
koolaid5 is offline
post #1558 of 2210 Old 12-05-2012, 01:18 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Wanted to get these painted AND installed. At least I got halfway there. . .
koolaid5 is offline
post #1559 of 2210 Old 12-05-2012, 01:21 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Need to pick up some trailer lights for these next.
koolaid5 is offline
post #1560 of 2210 Old 12-07-2012, 08:54 AM
DriverX
Liking the THOR quarter guards. How was the install?
DriverX is offline
should i buy this $600 beater? sbens12889 XJ/MJ Cherokee Non-Technical Forum 15 01-05-2013 02:18 PM
My '94 XJ Beater Fix (...maybe build?) thakoolaidkid XJ/MJ Cherokee Non-Technical Forum 10 01-04-2013 09:12 PM
Build thread: "Black beater" 97 XJ 4.0l sahara XJ Cherokee Technical Forum 32 09-01-2011 03:41 AM
$300 trail beater saleen9973 XJ Cherokee Technical Forum 13 01-10-2010 12:29 PM
ESJA Beater Build Race... Cherokees catching air VamosJEEP XJ/MJ Cherokee Non-Technical Forum 0 07-01-2009 09:09 AM
