3" lift and wheels - JeepForum.com
post #1 of 14 Old 03-10-2012, 01:17 PM Thread Starter
canuckle
3" lift and wheels
Hey just curious if anyone knows if 31x10.5 tires on a 3" lift rub or touch in any way? It's my dd and I don't want to cut or trim anything. With a 3" lift does that guarantee no vibrations? Also where in central Alberta can I find cragar 8's, local tire shop is no help
canuckle is offline
post #2 of 14 Old 03-10-2012, 01:53 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
With a 3" lift you may or may not have vibrations it all depends on the Jeep .
My XJ Rubs with a 3" and 31's but it only rubs when offroad with a tire stuffed into the fender well with the wheel slightly turned
I do not get any vibrations with a T-case drop in my XJ
As for where to find Soft 8's in Canada I cant help you there
See pics for how wheels are when my tires rub the bottom edge of the bumper end caps
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 14 Old 03-10-2012, 02:40 PM Thread Starter
canuckle
Pics look good! I ordered a BDS 3" kit yesterday then I started worrying about vibes and getting a SYE. Is there a good online wheel tire combo in the U.S? Local tire shop goes by plus or minus millimeter offset and I just know I need 4.25" backspace
canuckle is offline
post #4 of 14 Old 03-11-2012, 08:59 PM
Tom95YJ
Tom95YJ's Avatar
I run 3.75" Backspace 3.75 to 4.5" backspacing works great for XJ's
4wd.com
will allow you to create a wheel and tire package Their Rock Crawler wheels are tuff as nails I've ran them on 3 different Jeeps with out bending any of them, My friend totaled his 97 TJ when it rolled 4 times a few years back after hitting black ice and going sideways at 60mph he was running rock crawler wheels an they were still strait even after the violent rolls, He is running those wheels on his 05 Rubicon
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 14 Old 03-13-2012, 11:22 PM
GregB_00XJ
Yes, 3.75-4.5 is the shiz. I run 3.75" BS on 15x8 with 31 x 10.5 x 15 and around a 3.5" lift (was taller has sagged some). If I were to do it again, I would go 4-4.5" BS.
Good call on the BDS kit, they make really nice stuff.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #6 of 14 Old 03-14-2012, 07:28 AM
VegasGT
1988 MJ Comanche
I run 4" backspacing now but ran 4.5" on my 01 with 3" lift and really dug the look. That backspacing will help keep you from rubbing on the body as well when compared to 3.75".
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #7 of 14 Old 03-14-2012, 10:07 AM
billabongopblue
Mine rubbed on the bottom inner fender. This is due to a lack of lower control arms with the lift i purchased. This was with 3" 31's and 4" backspacing.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #8 of 14 Old 03-14-2012, 10:31 AM
Azzy
I had rubbing at 3" and 31s with stock wheels, and then I decreased the backspacing (spacers) 1" and no more rubbing on the control arms.
Up and down isnt an issue, bumpstops are set properly, if not a tad redneck style (hockey pucks RTV'ed to the spring perch)
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #9 of 14 Old 03-14-2012, 01:16 PM
jeepxj9901
On my first jeep I had a 3" RC add a leaf lift with 31s and craft soft 8s. It rubbed a good amount. Added 1.5 spacers within two weeks to get rid of rub
2001 XJ 4.5" RC X-series lift with shackle relocation kit and control arm drop brackets. 31x1050x15 Mickey Thompson Baja MTZ and 15x8 Mickey Thompson Sidebiters. Neosupreme seat covers
Build thread- Kado 01XJ
jeepxj9901 is offline
post #10 of 14 Old 03-14-2012, 01:18 PM
jeepxj9901
By 1.5 I mean 1.5 lift (spacers and extended shackle)
post #11 of 14 Old 03-17-2012, 04:54 PM
Lnthiess
Mine rubbed so we had to do some minor trimming
Lnthiess is offline
post #12 of 14 Old 03-17-2012, 07:30 PM
BlueBadger
I have a 3" RC lift and had 31's robed a little. Then I put 33's 12.50 on 15 by 10's pacer D spokes. Now I need new front fenders and a few more inches of lift. Lol
BlueBadger is offline
post #13 of 14 Old 03-17-2012, 07:34 PM
BlueBadger
Sorry meant rubbed a little. And had to do some trimming and bent the pinch weld seam back.
post #14 of 14 Old 03-17-2012, 09:17 PM
mikeoc1
I have a RC 3" lift. I had to drop TC to get a smooth ride. So far my 31s with 4.5 bs arent rubbing but havnt been off road with them yet.
mikeoc1 is offline
Will these wheels/tires fit on my XJ with a 4.5" lift? cutter1024 XJ Cherokee Technical Forum 12 05-08-2011 04:21 PM
30" tires on OEM wheels...1.75" lift samger2 XJ Cherokee Technical Forum 9 11-18-2008 07:10 PM
RE 3" lift...15x8 wheels 32x11.5" tires Rynxprs XJ Cherokee Technical Forum 6 06-22-2008 06:20 PM
New Tires and Wheels and 2" lift on DD black2002ws6 XJ Cherokee Technical Forum 18 02-27-2008 06:05 AM
New Tires and Wheels and 2" lift on DD black2002ws6 XJ Cherokee Technical Forum 2 02-25-2008 12:33 PM
