2001 Jeep Cherokee RHD - JeepForum.com
post #1 of 6 Old 02-14-2012, 06:21 PM Thread Starter
annienet
Just purchased a RHD Jeep in Pa and drove home with very little heat! A little cold before we got it home. Didn't notice this before I paid him for it. I hope there is a special place for used car salesmen! As I am looking at posts I am seeing posts about the blend doors. Will I have as much cold air blowing as well as some warm air if the blend door is broke? Also what else should I be looking at to be sure this is the problem? TIA
annienet is offline
post #2 of 6 Old 02-14-2012, 06:45 PM
VegasGT
1988 MJ Comanche
Probably more of an issue for tech, but oh well, im feeling helpful.
If you arent having heat, and it is blowing cold air, check your temperature gauge. If its not pretty much in the happy middle around 195 mark, you are looking at a thermostat stuck open or possible non-existent depending on the IQ level of the previous owner.
If it is running at normal operating temperature, might want to check into flushing your heater core. Plenty of info on that topic using the search function.
I would only look into your blend doors if you can tell you are getting hot air SOMEWHERE but maybe it isnt getting to the right places. If its just blowing cold/cool-ish air then its more than likely a derivitive of the above scenarios.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #3 of 6 Old 02-15-2012, 09:06 AM
TheAquatard
For the peace of mind, flush the coolant system, get a new thermastat and really blow out the heater core good before refilling. So much junk gets caught in there. It's a real common problem.
TheAquatard is offline
post #4 of 6 Old 02-15-2012, 09:49 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Service the cooling system, flush the heater core, and then worry about blend doors.
Use a flushing/cleaning solution and then drain and fill the radiator with a fresh 50/50 coolant and water mix. With a neglected cooling system you may have to flush several times.
-Inspect the radiator for mud/bugs/grass clogging the outside and mineral deposits clogging the inside. Clean or replace as needed.
-Replace the thermostat with a STANT or Robertshaw 195* thermostat. Cheap thermostats are cheap for a reason.
-Replace the radiator cap if your Jeep has one. An old worn out cap will allow boil overs and/or allow the coolant flash over into to steam. You will see the coolant temps suddenly jump from 210* to the Red Zone and back to 210* if your radiator cap is weak.
-Inspect/test or replace the mechanical fan clutch. A worn fan clutch will allow temperature creep at stoplights, in heavy traffic, and on the 4x4 trails. A fan clutch that “looks” OK is not the same as working OK.
-Inspect the electric cooling fan and the fan relay. Apply 12 volts and make sure the fan runs. Exchange the cooling fan relay with one of the others similar relays. Confirm that the e-fan starts when engine temps reach 215-218*. Repair or replace the fan or relay as needed.
-Inspect/test or replace the coolant temperature sensor that activates the e-fan.
-Replace the water pump. The pumping fins can deteriorate over time and the pump will not flow enough coolant to keep the temps under control.
-Inspect/replace the radiator hoses. Make sure the coiled wire is installed in the lower hose.
CJ7-Tim is offline
post #5 of 6 Old 02-15-2012, 12:54 PM
Chaseg08
As the other guys said, flush fluids first then check your heat. It's very possible you need a new heater core. There is a great thread covering heater core replacement and there are many people here who have had to do it. Heres a link to that thread: http://www.jeepforum.com/forum/f11/m...thread-592844/
Chaseg08 is offline
post #6 of 6 Old 02-15-2012, 02:14 PM Thread Starter
annienet
Thank you all for your help! Hubby back flushed the heater core and thinks I now have heat. Next we will be checking the steering it has a little more play than I am comfortable with on the gravel. Thank you again I may be back with more questions!
annienet is offline
2001 Jeep Cherokee Shoup XJ Cherokee Technical Forum 5 05-04-2008 05:49 PM
2001 jeep Cherokee timmur XJ Cherokee Technical Forum 1 10-17-2007 12:35 PM
2001 jeep Cherokee timmur XJ Cherokee Technical Forum 16 10-05-2007 11:03 PM
2001 jeep Cherokee timmur XJ Cherokee Technical Forum 3 10-05-2007 09:00 PM
HELP with 2001 Jeep Cherokee 4x4 anthonysmith XJ Cherokee Technical Forum 7 05-13-2006 11:18 AM
