2" Suspension: Rancho RS66000 vs BDS 428H vs Rusty's RK-200AL-XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > 2" Suspension: Rancho RS66000 vs BDS 428H vs Rusty's RK-200AL-XJ
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 05-21-2014, 01:56 AM   #1
jae-hova
2" Suspension: Rancho RS66000 vs BDS 428H vs Rusty's RK-200AL-XJ vs Superlift K369
I just picked up a 95 XJ with 55K miles in pristine condition. Ive never owned or lifted a jeep, but from what ive been reading 2" is the way to go if I want to avoid any problems or having to add a SYE and swap the CV Shaft. I dont want to do a budget boost, I want to add a suspension lift. Please let me know if you have had any good or bad experience with the following lifts. Everyone seems to agree that OME makes the best suspension lift, but its a little out of my budget if I wanna add rims and tires as well. Also, the BDS and Rusty's come with shocks (which I assume are junk) but the Rancho doesnt. What shocks would you recommend. This is going to be a DD that I will use to haul a toddler and a baby and will occasionally get some trail time.
Rancho RS 66000 vs BDS 428H vs Rusty's RK-200AL-XJ vs Superlift K369
thanks
Last edited by jae-hova; 05-23-2014 at 07:53 PM.. Reason: add lift kit to the discussion
jae-hova is offline   Reply With Quote Quick reply to this message
Unread 05-21-2014, 12:11 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
BDS lifts and shocks are top quality and have an excellent warranty. The others, not so much. Buy the BDS.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 11:33 PM   #3
jae-hova
If I did go with the BDS is it necessary to replace Upper & Lower Control Arms???
Unread 05-22-2014, 11:42 PM   #4
jae-hova
Unread 05-23-2014, 04:08 AM   #5
roadraje
^that's what I did, no regrets.
'99 XJ Limited…a work in progress.
'99 WJ…almost there.
roadraje is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 04:09 AM   #6
roadraje
No, but I found a pair of WJ LCA's locally so I put them in while I was at it.
Unread 05-23-2014, 12:20 PM   #7
CJ7-Tim
CJ7-Tim's Avatar
What about Superlift K369?
...is it necessary to replace Upper & Lower Control Arms???
Not with only 2" of lift.
