1999 XJ w/ cracked exhaust manifold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > 1999 XJ w/ cracked exhaust manifold
Currie Antirock, Currectlync & Lift Kits on Sale!Oconee Off-Road Free Shipping Lifts Tires Bumpers Tops andIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-12-2014, 01:24 PM   #1
Victoria
Hi! Some quick questions. Seller wants 2,000 for 1999 XJ with 175,000 miles. How much to replace rear U joint and cracked exhaust manifold? Is it worth buying this jeep and getting it fixed? Any input from you XJ vets would be greatly appreciated.
Thanks!
https://peoria.craigslist.org/cto/4705989420.html
Victoria is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 06:42 PM   #2
wizardPC
Any XJ will have a cracked exhaust header unless it's already been replaced. That wont affect operation or emissions.
I'd be more worried about the "some rust"
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 08:01 PM   #3
WhammyXJ
Get the seller as low as possible and buy it. Seems fair to me (outside of the fact is is an automatic).
======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
WhammyXJ is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 05:26 PM   #4
bobthecatkiller
Wait what...
Not every xj has or will have a cracked header, it should make you run rich because now your o2 sensor will be out of wack, and depending on its size it may annoy the hell out of you or the cops in your area...
Welding the leak is usually a temp fix, I suggest replacing it yourself otherwise its going to cost you quite a bit at a garage, and really its pretty easy, just time consuming
officer: What where you doing down by the river?
me: awww ahhhh awwww exploring?
officer: mudding?
me: yaaaaa.
bobthecatkiller is offline   Reply With Quote Quick reply to this message
