1998 jeep cherokee sport #3 cylinder miss fire - JeepForum.com
post #1 of 7 Old 05-21-2013, 06:13 PM Thread Starter
modsjeep11
Hey my jeep has a miss fire in #3 cylinder and it's internal any ideas to help fix the issue!!! Please help!!
modsjeep11 is offline
post #2 of 7 Old 05-21-2013, 06:26 PM
sluff28
1975 CJ5
what year is the jeep and research heat soak.
sluff28 is offline
post #3 of 7 Old 05-21-2013, 10:03 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Uh, I'd guess it's a '98 Jeep Cherokee Sport.
D3<!L!>3D
S8NNG8 is online now
post #4 of 7 Old 05-22-2013, 03:23 AM
sluff28
1975 CJ5
Didnt see the year in the first post dont be a d@#k. If you want to contribute put somthing usefull into the members thread. don't clutter it up with smart comments.
Now for the problem if it is a heat soak issue there is a shield you can put on but it didn't help with my heat soak. The only fix I have ever found that worked well was a switch wired to my a fan so on short stops I could just turn my fan on and that kept the engine cooler by moving air over the engine
sluff28 is offline
post #5 of 7 Old 05-22-2013, 06:30 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
It wasn't in the first post. It's the title of the thread. As for the problem, do hood vents.
D3<!L!>3D
post #6 of 7 Old 05-22-2013, 12:23 PM
LimeLJ
LimeLJ's Avatar
You need to learn some humility.
Modsjeep11, the 1999+ 4.0L engines are notorious for heat soak issues that caused vapor lock with injector #3 due to the design of the newer intake. However, the 1998 and older designs are not entirely immune to this issue either. The first cheap fix to try is to wrap heat shielding material, such as DEI heat wrap, around the misfiring injector. If it turns out that heat soak is not the issue then it will be down to a faulty injector or wiring to that injector.
LimeLJ is offline
post #7 of 7 Old 05-31-2013, 07:33 PM
nebo29
[QUOTE
Modsjeep11, the 1999+ 4.0L engines are notorious for heat soak issues that caused vapor lock with injector #3 due to the design of the newer intake. However, the 1998 and older designs are not entirely immune to this issue either. The first cheap fix to try is to wrap heat shielding material, such as DEI heat wrap, around the misfiring injector. If it turns out that heat soak is not the issue then it will be down to a faulty injector or wiring to that injector.[/QUOTE]
http://www.wjjeeps.com/tsb/tsb_wj_1803103.pdf
XJ Limited Club Member #5
nebo29 is offline
