1998 cherokee sport high mileage - JeepForum.com
post #1 of 3 Old 03-20-2013, 09:22 AM Thread Starter
blakehill3
Im new to jeeps and i just got this jeep a couple months ago. Its currently at 196000 miles and i just got the oil changed about 1000 miles ago. I was wonderin if there is anything i should do to make it run longer? I know there is high mileage oil but i was wondeing what kind i should use and if i should mix anything with it.
blakehill3 is offline
post #2 of 3 Old 03-20-2013, 10:21 AM
bobthecatkiller
If it ain't broke....
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is online now
post #3 of 3 Old 03-20-2013, 06:29 PM
dmill89
1995 XJ Cherokee
Since when is 196k high mileage for an XJ?
Basically, I would just change all the fluids if you don't know the last time they were changed or if they are due. You may want to replace the belts and hoses depending on age and condition. Aside from that there's really nothing special necessary aside from normal maintenance. If you change the trans fluid (auto) make sure to use DexronIII/Mercon this is what the Aisin AW4 takes (the transfer case also uses this).
As for oil the 4.0L I6 isn't picky, it will run on just about anything that says "Motor Oil" on the bottle (5/10w30 or 5/10w40). That being said high-mileage oil can't hurt, Shell Rotella T5/T6 are also popular options which tend to perform well in the 4.0L. Just make sure to use a good filter (not Fram, STP, or an off-brand) Purolator (especially the PureOne), Mopar, Wix and NAPA Gold (rebranded WIX) are the preferred filters.
dmill89 is offline
