1987 xj wagoneer build thread - JeepForum.com
post #1 of 24 Old 01-26-2012, 11:03 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Year: 87
Model: XJ Wagoneer
Miles(per odometer): 235,XXX
Color: Gold/Brown
Current mods: None as of yet
Current Condition: restore/rebuild
Bought it for 500$ and it has very little surface rust from what I can see currently. Interior is absolutely MINT condition no tears in the seats what so ever and 0 wear and tear. Does not run but the engine, trans, and tcase are already out of it.
The engine is already torn down to the block, and about to head to the machine shop. over the time that the engine is getting machined and the head is getting a nice little valve job, Ill be getting all the engine bay wiring and other engine bay components cleaned up. P/S pump, A/C compressor, and Alternator are all in good shape for being 25 years old. brackets are being cleaned, blasted and painted. Valve cover is getting the same treatment.
Ill be working on major mechanical at the house and the rest of it ie: Brakes, Steering/Suspension, HVAC, Wiring, and Tcase are all being done at school. I plan on having it functional in about 3-4 months of about 4hours of work 3 days a week at school.
PS i know its weird that i seem to have saved the entire first page but..... i rather keep all build process info in one place thanks for your understanding.... (bite me if you dont)
Papabear0102 is offline
post #2 of 24 Old 01-26-2012, 11:04 PM Thread Starter
Papabear0102
1994 XJ Cherokee
The day i got it dropped off
post #3 of 24 Old 01-26-2012, 11:05 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Brakes:
When it was dropped off it had an almost dead pedal, and the passenger side primary and secondary drum shoes were reversed.
so i took the passenger side drum apart cleaned and properly assembled the drum. Then bled the entire system. now i have a good stiff pedal and correct brakes
ill start taking pictures when i really get into them and cleaning and replacing parts.
post #4 of 24 Old 01-26-2012, 11:05 PM Thread Starter
Papabear0102
1994 XJ Cherokee
steering/ suspension:
The rear suspension is sagging a little and the shocks all the way around need replacing. the bushings across the steering components show some wear but are pretty tight at all ends. Cant really tell fully due to the engine being out and really no load on any of the front suspension/steering components.
More when the engine goes back in
post #5 of 24 Old 01-26-2012, 11:06 PM Thread Starter
Papabear0102
1994 XJ Cherokee
interior work
The interior the day i got it. other than dirty its not half bad just needs a really good clean!
post #6 of 24 Old 01-26-2012, 11:06 PM Thread Starter
Papabear0102
1994 XJ Cherokee
exterior work
post #7 of 24 Old 01-26-2012, 11:07 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Engine work
The day i got it.
3rd day
4th day
the head off Pistons show common wear, but cylinder 5 and 6 both have broken rods at the crank. So ordering new pistons, rods, rings, and bearings here soon.
all torn down
The original pistons
Pistons 1,2,3
Pistons 4,5,6
Pistons 5,6 snapped rods at the crank. lucky enough no valve damage and very little crank damage.
The crank is in decent shape. Glad i don't have to buy a new one.
The valves
One of the brackets after about 4 hours in the parts washer
and one of the main caps for the crank
bout to head back out and get the brackets cleaned up and into the blast cabinet. more pictures up later
post #8 of 24 Old 01-26-2012, 11:07 PM Thread Starter
Papabear0102
1994 XJ Cherokee
g
post #9 of 24 Old 01-26-2012, 11:08 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Sound System
N/A
Soon to come
post #10 of 24 Old 01-26-2012, 11:09 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Custom Storage
N/A
Soon to come
post #11 of 24 Old 01-26-2012, 11:09 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Ideas/Mod list
N/A
Soon to come
post #12 of 24 Old 01-26-2012, 11:10 PM Thread Starter
Papabear0102
1994 XJ Cherokee
other 1
post #13 of 24 Old 01-26-2012, 11:10 PM Thread Starter
Papabear0102
1994 XJ Cherokee
other 2
post #14 of 24 Old 01-26-2012, 11:11 PM Thread Starter
Papabear0102
1994 XJ Cherokee
Other vehicles
00 Mitsu Eclipse
86 F250 w/ 6.9
My 96 xj country
Stock muddin trip
sadly this was wrecked by my sister. flipped 4 times
post #15 of 24 Old 01-26-2012, 11:12 PM Thread Starter
Papabear0102
1994 XJ Cherokee
other 4
1987 XJ wagoneer with 22k miles.. wow MiZZ XJ/MJ Cherokee Non-Technical Forum 4 01-21-2012 11:04 AM
1987 Wagoneer 4.0 automatic JeepRyderz XJ Cherokee Technical Forum 1 06-28-2010 09:38 AM
1987 jeep wagoneer problems xj1987Wagon XJ Cherokee Technical Forum 2 01-06-2010 09:29 AM
1987 Cherokee (Wagoneer) Brake problems BigNews1 XJ Cherokee Technical Forum 0 02-15-2008 12:28 PM
1987 wagoneer stroker update Somthor XJ Cherokee Technical Forum 14 11-05-2004 10:53 AM
