1987 Cherokee - New Owner/Victim ;) - JeepForum.com
post #1 of 11 Old 09-30-2013, 08:24 PM Thread Starter
castlerox
1987 XJ Cherokee
Hi all,
I will be a newbie to this forum but most likely a frequent one.
Long story... came across a good deal on a 1987 v6 XJ. I have no idea about Jeeps and have never owned one. I am pretty excited to tinker with the JEEP platform.
1987... Thoughts? Things I need to look at? The steering is a bit loose and wonky.
I absolutely love the spartan nature of this interior. Manual everything except transmission.
It's a REALLY good interior and the exterior id so so with paint fade...
Just looking for any 1st timer advise on a 1987 and say hello b/c I will be on here alot
THANKS!
Matt
castlerox is offline
post #2 of 11 Old 10-01-2013, 05:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Nothing wrong with an 87.
Click on the link in my signature and see the cheap and easy fixes/upgrades you can do for little to no money. Just some time getting familiar with your Jeep. The auto trans is an excellent trans and will serve you well.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 11 Old 10-01-2013, 07:27 AM
cbenez1
Welcome aboard. As cruiser stated, nothing wrong with an 87. First thing you'll want to do on this forum is fill out your vehicle profile. When you ask questions a lot of us will go to that to find out specific info (ex. transmission, rear axle type, 6cyl or 4cyl) on your jeep to help us give you accurate answers. Info is key.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #4 of 11 Old 10-01-2013, 09:02 AM Thread Starter
castlerox
1987 XJ Cherokee
I will get it all updated once I have it. I am going to pick it up today.
I was going to have one last look before handing the cash over which was kind of the point of this post
So far to my knowledge it is an automatic v6 4x4.
It seems to shift OK. Engine feels good. Didn't overheat and the A/C blows beautifully.
I will update everything once I have it - other than that are there any absolute "If you see this..." Red Flags?
post #5 of 11 Old 10-01-2013, 10:24 AM Thread Starter
castlerox
1987 XJ Cherokee
By the way - do these have a tough time passing emissions? I see it has a CAT installed.
post #6 of 11 Old 10-02-2013, 09:37 PM
cbenez1
None of the 5 XJ's I've owned had any unusual emission problems.
cbenez1 is offline
post #7 of 11 Old 10-02-2013, 10:24 PM
AGDubyaJ
Its mostly likely a 4.0L inline 6, the V6s were only used up until 86.
that being said, you will like the 4.0L engine, one of the best ever made IMO
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #8 of 11 Old 10-12-2013, 11:17 AM Thread Starter
castlerox
1987 XJ Cherokee
Hi all.
We went ahead and grabbed this "deal"... I have to say I love this little wagon.
I bought it for my Girlfriend. She has been using it as a DD since purchased. It passed emissions no problem. The interior is nearly perfect. AC is arctic cold. The outside paint is faded from the AZ sun but actually aged nicely due to it being a Goldish color previously. Vintage Petina!
So far it has needed nothing and I haven't had the time to get into it yet...
We came in at $1600 - it as about 250k on it. Everything seems fine EXCEPT:
Sterring - it is pretty sloppy. I am not familiar with Jeep at all. In fact, where is the RAD cap?
I am wondering the best way to have a look at the suspension/steering. Common issues that could cause slop. Linkage, CA's, Idlers... I have no idea. Totally new to the Jeep platform.
Chime in if you have any idea on what we should look at for this thing.
Thanks!
1987 Cherokee 4.0 V6
post #9 of 11 Old 10-12-2013, 12:30 PM
Motorcharge
Your year has a closed cooling system so there is no radiator cap. There's a coolant reservoir/overflow in the back of the engine bay that you fill from.
They're fairly temperamental so switching to an open cooling system later if you have issues is usually a good idea.
Bookmark this, tons of good info on Renix era XJs.
http://www.cherokeeforum.com/f51/cru...x-tips-153657/
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #10 of 11 Old 10-12-2013, 05:32 PM
dmill89
1995 XJ Cherokee
Sterring - it is pretty sloppy. I am wondering the best way to have a look at the suspension/steering. Common issues that could cause slop. Linkage, CA's, Idlers... I have no idea. Totally new to the Jeep platform.
Tie-rod ends would be the first place to check, also check the steering stabilizer (like a shock-absorber for the steering). At 250k mi your steering box may be worn as well, though TREs are much cheaper and more failure prone so that would be the first place to look. The XJ uses the old-style recirculating ball steering so it will never be exceptionally precise even in perfect condition.
dmill89 is offline
post #11 of 11 Old 10-12-2013, 07:41 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See the cap on the bottle? Replace it with a Napa 703-1396 first chance you get.
