$150 slow 2 door build. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > $150 slow 2 door build.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitClayton Off Road - Come see us at these events!
Unread 01-19-2014, 06:18 PM   #1
BeauDuke01
1990 XJ Cherokee
Ok, so the story starts a little over a year ago.
A good friend of mine traded his Yamaha scooter for a full sized chebby blazer, something about tired of being almost run over because people dont pay attention.
We went with him a couple times at a small offroad park mainly designed for quads and atv's, but had a pretty good time. So natural progression was to find my own small 4x4 something to go and play around in.
And thats where the story takes an odd turn. Since we live in oil country, everyone thinks that their used vehicles are worth their weight in gold. I looked at s-10's and rangers, and nissans, and nothing that was anywhere near my price range ever popped up.I was trying to avoid going jeep because my younger brother is a freakin jeep fanatic.
However, i started looking at xj's, and still, everyone wanted way to much money for them.
So i made the call.
"Damn Jack, xj's are waaay to freakin expensive anymore!"
To which he responds, "well, i know where there is one cheap that needs a little work."
Famous last words.
A guy he know in Amarillo started a 4.0 HO swap into his 90 xj, and lost interest. "it just needs some wiring finished up, they told me it should take a weekend to have it running."
Anyone have any property they'd like to sell me?
i bit, hook line and sinker.
A thousand bucks, and Jack delivered it to my back yard.
'90 xj, 4.0ho aw4 and 231 with sye, waggy d44's front and rear. 6" lift with brand spankin new swampers and some pro comp wheels, and mx6 shocks up front.
All things considered, not a bad price. My buddy, who is a mechanic at a Dodge dealership, told me he'd help me get it running. Again, gullible me fell for it.
It sat in the back yard, and id mess with it here and there, changed the flywheel, cause it still had a 98 model one in it, swapped in a new cps, new cap and rotor, still wouldnt fire. No matter what we did, or what we tried, i just couldnt get it going.
well, last October, Jack invited me to Grand Slam in Hidden Falls, told me i could wheel his jk, so we went down, had a blast and met some great people.
Really had a blast. Got me hooked really good on crawling. While we where there, super cool guy Jeremy said "Hey, my buddy has a "96 2 door for sale for $150..."
So its off to the races once again. I got the vast amount of cash required for the transaction, they tell me "It only needs a starter and a battery"
Once again im thinkin imma get hosed, but we get together, get a trailer, grab my spare battery and head over.
Jack got in and put the key in the ignition and it started with that annoying *** door buzzer.... welp, we dont need no stinkin batties, so we wrapped a tow strap around the axle, hooked it to the jk, and Jack pulled me and we pull started it, so i drove it onto the trailer. Then began the exited journey home, as i had just purchased a running driving vehicle for a measly $150.
Jack even let me drive the jk around again.
Ok, here we go again.
We get the thing home, and unload, and pull start it one more time, so i can get it around to the back yard to introduce it to its big brother...
i think its a bit intimidated.
It does have a bit of growing up to do.
so a few details on the new one, '96 2.5 ax5 4.11 rearend.
So a trip to Vatozone, and $80 later, I have a new starter, and battery cable end, whoever decided e torx bolts where a good idea, i hope they have fingernails growing out of their nose that require bolt cutters to clip, i hate those things.
The next day, i got the starter put on and the jack stands pulled out, and go to start the thing... no dice, just cranks and never fires. One phone call to my older brother later, hes over at the house and we pull start it once again, with one small mishap.
Ronnie thinks its absolutely hilarious to floor his truck while we are trying to pull start mine, trashing the pass side bumper bracket. So we push the bumper back into place, and away i go. Jeep runs just fine, sounds like a dozen midgets in the engine compartment beating it to death with hammers, but it runs fine. Needs a timing set by the way.
So off to Vatozone once again, time for a tune up. Man o man, do i hate the counter monkeys at that place, they dont know their *** from a hole in the ground. They didnt have a wireset, or a dist cap, or a rotor... so off to oriellys. Those guys have everything i need in a one stop shop.
home again home again jiggity jig, pushed the jeepmobile into the middle of the back yard and got to work, pulled the battery, pulled the belt, pulled the ac compressor, just to get at the front plugs.
these things had to be the originals...
They where worn down to a .054 gap, so i gapped the new plugs, and tossed em in. then comes the fun part, i started pulling alll the wires off the dist cap to put on the new one, all 4 cyl wires came off nice and easy, but when i grabbed the coil wire and pulled... dust came out...
wonder if this is why it wont start on its own?
So reassembly begins, new rotor, cap, wireset, plugs, and put it all back together... reach through the drivers window, checked to make sure its in neutral, and bumped the key...
sweet music to my ears, fires up and runs like a kitten, well...an epileptic kitten in a stew pot, damn that clattering from the timing set.
So after some joyriding down residential neighborhoods, no registration or inspection yet, it was time for a bit of a clean up.
Drove it to the front yard and got out the shop vac, it had sat for a year or so and was dusty and dirty.
Got it all cleaned up and dust free on the inside, and decided i didnt like the goofy 8 ball shift knob, so i got a goofy skull....
it adds 15 hp.
Now for the fun part, the plan is, to strip all the goodies from my 4 door, and put them on the 2 door... so i need a 4x4 ax5 to finish my swap, and I'll have d44's front and rear, which I'll have to re gear to prolly a 5.88, just so my 4 banger will have a chance and a little more low end.
Thats pretty much it for now, the oil pan and valve cover gaskets both leak like the Exxon Valdez, and the timing set sounds like gremlins trying to escape the front of the motor, but it runs, drives, steers, and stops, and im pretty happy with than so far.
ok, so... my buddy Sam had a pair of coil spring spacers for dirt cheap, so I paypalled him some money. I can at least have it a little taller while i finish getting all my parts together for the 4x4 swap. i convinced the wife to go to the j/y with me tomorrow to grab a few things as well. hopefully i can find a 97+ console. im also grabbing a few door lock sets so my buddy Todd can re key the xj to use the key i have for my ram and durango, its amazing only having to keep up with one key for everything.
BeauDuke01 is offline   Reply With Quote
Unread 01-19-2014, 06:19 PM   #2
BeauDuke01
1990 XJ Cherokee
I didnt feel like hanging out around the house today, so i grabbed the AR and the 12 gauge and threw them in the back of the xj, and drove to the farm. Since its about an hour one way, i took the wife as well, jeep did really well, sounds like i need to change the wheel hubs, but it rides pretty smooth. While i was there, i also did a little stock poser flexin, so I'll shut up now, and show pictures.
Unread 01-19-2014, 06:35 PM   #3
YJ_89
Junior Member
YJ_89's Avatar
Sounds like you got an awesome deal on the 2 door.
1989 YJ 4in 33's. My Build Thread
YJ_89 is offline   Reply With Quote
Unread 01-19-2014, 06:38 PM   #4
BeauDuke01
1990 XJ Cherokee
nah, I'm going to use the '90 for an organ doner, put all the good stuff under the '96, the motor will prolly go to MGDWJ, as a spare for his buggy. after that i havent a clue what i'll end up doing with the rest of it
Unread 01-20-2014, 07:37 AM   #5
DNFJ
DNFJ's Avatar
Where the **** do people keep finding cheap 2door XJs, I'm getting mad that I don't have one.
Nice find and good work so far man.
[CENTER][SIZE="1"][Color="Blue"][b]00 XJ Sport "Wannabe Desert Rat"[/b][/color](August 2012-Present) 4.0L - 160k Body, Monstalined Menace, ATK+ Longblock, 6.5" IRO Short Arm Lift, LMP Front Bumper, Bushwacker Flat Flares, Clayton DS Track Bar, ZJ V8 Steering, Quick Discos, Bilstein 5100s, IRO HnT SYE, Braided SS Brake Lines, 1" TC Drop, HiLift, #784 Injectors, Flowmaster Super 44, 33" BFGoodrich A/T on Outlaw IIs, Safari Snorkel, Autopal Harness + 80/100w H4 Bulbs[/SIZE]
[URL="http://www.jeepforum.com/forum/f177/blue-waffle-build-thread-1807113"][SIZE="3"][FONT="Arial Black"][COLOR="Blue"]Blue Waffle Build Thread[/COLOR][/FONT][/SIZE][/URL]
Built Not Bought #704[/CENTER]
[SIZE="1"][i]Past Jeeps:[/i]
[Color="Red"][B]93 ZJ Laredo[/B][/color](Jan 2011-April 2011) 5.2L - 98k, Stock - Totaled
[COLOR="Tan"][B]96 ZJ Laredo[/B][/COLOR](April 2011-August 2012) 4.0L - 138k, Cowl Intake, Rancho 9000 Series, 2" Spacers, 31" Baja MT Widetracks - Sold[/SIZE]
[SIZE="1"][COLOR="silver"]Monstaliner: [url]http://monstaliner.com/[/url]
Iron Rock Offroad: [url]http://ironrockoffroad.com/[/url][/SIZE][/COLOR]
DNFJ is offline   Reply With Quote
Unread 01-20-2014, 11:46 AM   #6
um7267
nice looking jeeps on both fronts shame you cant get the 90 to run, did you check the crank position sensor?
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline   Reply With Quote
Unread 01-20-2014, 02:09 PM   #7
BeauDuke01
1990 XJ Cherokee
yessir, did the cps, did a new dist with new cap and rotor, reset the timing till i could do it in my sleep. put alot of little things into it, just couldnt get it to run.
Unread 01-20-2014, 02:13 PM   #8
BeauDuke01
1990 XJ Cherokee
i have some what of a build on what i did to the white one if you guys are interested.
http://www.jeepforum.com/forum/f177/...-side-1472199/
Unread 01-22-2014, 02:33 PM   #9
DPH1LLY
Looks like you got an awesome deal man. I can't wait to see what you do to it!
1989 Jeep Wrangler: Islander Edition w/
43,000 ORIGINAL miles & 1994
Jeep Cherokee Sport 2-Door w/ 140,000
miles
DPH1LLY is offline   Reply With Quote
Unread 01-22-2014, 02:59 PM   #10
BeauDuke01
1990 XJ Cherokee
thank ya sir.
Unread 01-26-2014, 08:47 AM   #11
Camfam07
cant wait to see what gets done on this one! you have a great donor vehicle.
Camfam07 is offline   Reply With Quote
Unread 01-28-2014, 10:00 PM   #12
danglenode
Pretty excited to watch this thread. Congrats!
danglenode is offline   Reply With Quote
Unread 01-29-2014, 05:36 PM   #13
Camfam07
Get er done
Unread 01-30-2014, 07:28 AM   #14
BeauDuke01
1990 XJ Cherokee
thanks guys, i called super cool guy Sam, and grabbed some coil spring spacers to rock around till i can find a new tranny to do my 4x4 swap. my little brother MGDWJ, drove to San Antonio and picked up a 9000lb two post lift, so it will make this stuff waaaaaaaaaaaay easier to play with. as soon as i can get back out to the farm, i'll snag some pics and get this thing updated.
Unread 03-21-2014, 08:46 AM   #15
SAMSET
yo, found your 2 door thread.
when are you going to start swapping over parts?
we are going to have to meet up in hot springs if you get a good wheeler.
...maybe i should throw project silver bullet up on this site...
SAMSET is offline   Reply With Quote
