#0331 Head a problem?? - JeepForum.com
post #1 of 2 Old 01-12-2009, 08:44 PM Thread Starter
angusdawg
Xj #0331 Head a problem??
All over the net, the #0331 head is a major problem. yet, all over this board members state that it is over blown hype. Which is it? It's easy to say find a well maintained one that hasn't been over heated. So, is this a major problem or a minor one?
angusdawg is offline
post #2 of 2 Old 01-12-2009, 08:53 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
It seems that the 0331 casting is easier to crack, when overheated. But I believe the problem gets blown out of proportion. Any head will crack if overheated enough. It just seems that with overheating that casting will crack more often than others. If your engine is kept in proper working order, and the fluids maintained, as well as the cooling system, you won't have anything to worry about.
xjfever is offline
0331 Head WMW0505 XJ Cherokee Technical Forum 138 02-20-2016 07:13 PM
0331 cylinder head 88wagon XJ Cherokee Technical Forum 2 05-20-2010 12:49 PM
question switching 0331 xj head to 98 tj head. jonnyz123 XJ Cherokee Technical Forum 1 05-15-2009 04:35 PM
0331 head swap 7120 removing the head from 92 to 2000 what all parts are needed amazingman XJ Cherokee Technical Forum 3 05-14-2009 12:57 PM
0331 Cyl Head crack XJride231 XJ Cherokee Technical Forum 1 12-28-2006 11:46 PM
