0331 cylinder head swap to 7120 any old trheads need advise - JeepForum.com
post #1 of 1 Old 05-09-2009, 09:40 AM Thread Starter
amazingman
I am doing the head swap i need some advice on what all parts are compatible from a 1992 xj to a 2000 xj? Or what parts i should remove from the 1992 brackets,sensors, should i remove the cam from the 92 and put it in the 2000 or should i just leave that alone.
What other parts should i remove from the 1992 to keep as parts i case i break any on the trail axel shafts sensors??????
amazingman is offline
0331 cylinder head 88wagon XJ Cherokee Technical Forum 2 05-20-2010 12:49 PM
any fixes for the 0331 cylinder head casting on 00-01's? dmcfan XJ Cherokee Technical Forum 8 02-19-2010 04:50 PM
0331 head swap 7120 removing the head from 92 to 2000 what all parts are needed amazingman XJ Cherokee Technical Forum 3 05-14-2009 12:57 PM
what is all needed for the 7120 to a 0331 head swap ????? amazingman XJ Cherokee Technical Forum 0 05-06-2009 01:19 PM
0331 to 7120 Head swap. Who has done it? Sugarfuzz XJ Cherokee Technical Forum 3 08-22-2007 09:12 AM
