01 XJ Sport spark plug recommendations? - Page 5 - JeepForum.com
post #61 of 97 Old 10-21-2013, 11:38 PM
DanTreE
Originally Posted by zaxfire69 View Post
Since nobody gives a rip what is in here..I'm changing to the Napa Gold 1515 oil filter in the morning. I usually put 6 quarts in..Will I need to put a little extra for the larger filter? Running 10w30....
I went this time..
4 quarts of Pennzoil 10w30 High Mileage because it was the only oil I could find in AAP with Zinc whatchamacolic still in it. 32 bucks
1 32oz Lucus Oil Stablizer on sale 11 bucks I think
1 K&N filters - 14.95
Jeep loves it. Also once every few changes I buy that cheap 21 buck oil change kit with a paper filter and cheap *** oil and I do a change, run it for a 20 minutes or so and then drain and do the real oil change.
For anyone who *****es about the waste of oil.. don't worry I use it for cooking after =)
96 XJ Country White with UNDER CONSTRUCTION TRIM. Blacked out Bezels and Grill.
235-75-15 Goodyear Wrangler Radials on Stock Black Mesh Alloy Rims
4.0I HO 4WD 160k Miles/Straight Pipe to my FlowMaster Super 44
~ Ain't not place to Jeep like a New York Street ~
DanTreE is offline
post #62 of 97 Old 10-22-2013, 04:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Buy 7 quarts. Put 6 in. Start it and build oil pressure. Wait 10 minutws and add oil as needed.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #63 of 97 Old 10-22-2013, 05:45 AM Thread Starter
zaxfire69
That's what I did. Going to it in just a little while. Next I need to change out the Diff Fluid.
zaxfire69 is offline
post #64 of 97 Old 10-22-2013, 07:28 AM
cbenez1
He said "Nobody gives a rip !"
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #65 of 97 Old 10-22-2013, 07:30 AM
cbenez1
No kidding, You run over 6 quarts ? I never used more than 5.5. TomAto / Tomato I guess.
cbenez1 is offline
post #66 of 97 Old 10-22-2013, 07:35 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I use 6 all the time and it's spot on. Been doing that since 87 when the 4.0 came out while working at the dealership.
Since he's concerned about the bigger filter, he may need a tad more.
post #67 of 97 Old 10-22-2013, 07:42 AM
cbenez1
Understood.
cbenez1 is offline
post #68 of 97 Old 10-22-2013, 01:00 PM
DanTreE
I understand the bigger filter but my stick marks FULL with 32oz lucus and 4 quarts.. You saying I should run it higher? PS oil pressure has been a tad to the right.. id say 50?
DanTreE is offline
post #69 of 97 Old 10-22-2013, 01:24 PM
mschi772
1997 XJ Cherokee
I use about 6 qts as well, but if for whatever reason 5 qts gets you to full (after running the engine to fill the filter), then whatever. Don't overfill.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #70 of 97 Old 10-22-2013, 02:18 PM Thread Starter
zaxfire69
50 Psi at speed 30psi at idle with 10w30 and Napa Gold 1515 filter. Picked up 5-10 psi at idle and 10 psi at speed. Wow... That is progress! Poor neglected XJ I'm sorry for running a crappy filter before.
post #71 of 97 Old 10-22-2013, 02:22 PM
cbenez1
TA DA !!! It's magic !
cbenez1 is offline
post #72 of 97 Old 10-22-2013, 02:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The XJ will forgive you. How much oil did you put in?
post #73 of 97 Old 10-22-2013, 02:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't use Lucas!!!
6 quarts of good oil and a Wix filter.
post #74 of 97 Old 10-22-2013, 02:56 PM
mschi772
1997 XJ Cherokee
Don't use Lucas.
Agreed.
mschi772 is offline
post #75 of 97 Old 10-22-2013, 04:33 PM
DanTreE
Don't use Lucas!!!
Love lucus. I def wont stop using it any time soon but I do wonder why the dislike. Used it since my first beast since my 78 monte carlo in 97. used it in all 8 of vehicles since. Never had an engine problem.. been at as I said 50 PSI of pres but its been like that and no one says anything bad.. with 4 quarts, 32oz lucus.
DanTreE is offline
