01 XJ Sport spark plug recommendations? - Page 2 - JeepForum.com
post #16 of 97 Old 10-07-2013, 06:36 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes. And spark plugs will NOT affect your engine operating temp. Something else is wrong.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #17 of 97 Old 10-07-2013, 09:42 PM
Muddy97Cherokee
1997 XJ Cherokee
Running temp isn't 210. 210 is when the aux fan kicks on and that is why its in the middle of the gauge. Running temp should be about 190.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #18 of 97 Old 10-07-2013, 10:00 PM
cbenez1
Originally Posted by zaxfire69 View Post
NGK's Gotta GO.....My Jeep will not get to operating temperature. I know it is cool outside, but it should at least get to 210 degrees and it isn't ...Probably around 180. I can lliterally see the gas needle moving. Even with my old plugs I had better gas consumption. Guess I will put new plugs like I had back in there. Were the NGK's suppose to be used with the coil packs our distributer model XJ's
If you can see your fuel gauge dropping you have another issue. (Like a hole in the tank) And like said above the plugs are not the reason for your engine temp issue.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #19 of 97 Old 10-07-2013, 10:52 PM Thread Starter
zaxfire69
It really isn't that serious. I am using more gas than normal, but I am going to run a full tank through it and see what happens. A full tank with my type of driving usually lasts me around 250 miles or so. Give or take. It has been around 90 degrees down here, but when this cold front came through it dropped temps into the 70's. Could be my temp difference. I won't shoot them down yet. It runs quite smooth with them in. For $2.39 I shouldn't complain. I did have the Bosch Fusions in there..With the exception of the one Autolite Platinum...???? They were in it for a long time. Way before I got it. I will fill the tank up and drive it like I do everyday and see how mileage looks then get back to you guys.
zaxfire69 is offline
post #20 of 97 Old 10-08-2013, 04:55 AM
mschi772
1997 XJ Cherokee
Copper NGK is the way to go in a 00 or 01 (copper Champions in 87-99). You shouldn't necessarily be hitting 210, and plugs wouldn't be a reason for temp issues anyway. Plugs also wouldn't be making you guzzle gas.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #21 of 97 Old 10-08-2013, 06:57 AM
cbenez1
Did you check the gap on each plug before installing them ?
cbenez1 is offline
post #22 of 97 Old 10-08-2013, 07:53 AM Thread Starter
zaxfire69
NGK ZFR5n's gapped to .035 using a wire gaping tool. I'm going to fill it up and see how many miles I get out of a tank of gas and compare. It runs very smooth, but it used to get to 210 and stay in the 200-210 range. It could be the temperature drop from 90's to 70 degrees outside. Like I said I'll run it for awhile then compare. It had the Bosch Platinum Fusion plugs in it. As far as idle and start up its perfect. Driving feels perfect. I'm going to watch those numbers and not get my revs above 2250 rpms and see what happens.
post #23 of 97 Old 10-08-2013, 11:35 AM
cbenez1
A lot of people don't believe it but these Jeeps truly run better on the standard plugs. The 96ish and under use the champions and the 97 and up use the factory NGK plug.
cbenez1 is offline
post #24 of 97 Old 10-08-2013, 03:24 PM Thread Starter
zaxfire69
I'm going to see how she does. Wish I could win the lotto so I could buy a lift and some new rims and tires for her. Ha Ha!
post #25 of 97 Old 10-08-2013, 04:05 PM
mschi772
1997 XJ Cherokee
Join the club. I need a lotto win just to do some rust repairs and other restorations. Buying toys like lifts and wheels is WAY in the future for me unless I find an insanely good deal.
mschi772 is offline
post #26 of 97 Old 10-08-2013, 05:33 PM Thread Starter
zaxfire69
I'm thinking about buying the Curt Roof rack.
post #27 of 97 Old 10-09-2013, 10:39 AM
cbenez1
Google Rage roof racks.
cbenez1 is offline
post #28 of 97 Old 10-09-2013, 05:20 PM Thread Starter
zaxfire69
I bought the Curts with extension. $130!!!shipped... You can't beat that!
post #29 of 97 Old 10-10-2013, 06:37 AM
cbenez1
Prices look about the same as rage but the Curt one looks better just going by the pictures. Let us know what you think when you actually get your hands on it. it
cbenez1 is offline
post #30 of 97 Old 10-10-2013, 07:45 PM Thread Starter
zaxfire69
Should be here tomorrow! I also think I have this gas situation figured out! Think it was cheap gas. Put name brand gas in it and it seems like it has done better. I still ordered Bosch IR Fusion plugs like what it had in it. They ran good so I'll go back with them. Yes they are 40 dollars for 6 on amazon.com, but they have a mail in rebate of 4 dollars a plug. $16 dollars total for Bosch Platinum IR Fusions isn't bad.
