01 XJ Sport spark plug recommendations? - JeepForum.com
post #1 of 97 Old 10-06-2013, 09:58 AM Thread Starter
zaxfire69
I'm about to change plugs in my 01 XJ Sport. It has the H.O. 4.0 and calls for the RC12ecc. I see folks say there are several different plugs you can run. When it is warmed up and idleing I feel a slight miss. What are you guys opinions on best plug to run for daily driving?
zaxfire69 is offline
post #2 of 97 Old 10-06-2013, 10:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Get NGKs.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 97 Old 10-06-2013, 10:21 AM Thread Starter
zaxfire69
What is the Number on NGK's?
post #4 of 97 Old 10-06-2013, 10:36 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Zfr5n
post #5 of 97 Old 10-06-2013, 10:55 AM
Muddy97Cherokee
1997 XJ Cherokee
The cheap copper ones are the best. 4.0's like the ****ty stuff.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #6 of 97 Old 10-06-2013, 11:16 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yup. Nuttin' fancy.
post #7 of 97 Old 10-06-2013, 11:27 AM
Muddy97Cherokee
1997 XJ Cherokee
I usually get the copper plus ones from AutoZone and they last me for awhile and make the engine run good. They are $2.00 a plug. But plug wires make the difference. Have found that good plug wires are better.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #8 of 97 Old 10-06-2013, 12:42 PM Thread Starter
zaxfire69
Sounds good. I've run NGKs in my Honda forever. Never had a problem. I'm on my way to get some now. Should I pick a spark plug wire puller up while I'm there?
post #9 of 97 Old 10-06-2013, 12:50 PM
Muddy97Cherokee
1997 XJ Cherokee
Never knew there was a spark plug wire puller. All of them are easy to get off. 1 and 6 are tricky.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #10 of 97 Old 10-06-2013, 01:21 PM
HawksWin
01 Should have the coil pack, Shouldn't need wire pullers.
HawksWin is offline
post #11 of 97 Old 10-06-2013, 01:49 PM Thread Starter
zaxfire69
It has coil packs . Looking at them now. Going to let it cool off awhile. Just drove it. Got the NGK's. 4 bolts and move a couple of hoses and I guess it should come off.???
post #12 of 97 Old 10-06-2013, 02:02 PM Thread Starter
zaxfire69
Guess this thing has a block heater on it. It has a 110v connector coming out from under intake Manifold. I'm guessing that is what this is. Don't need this in Mississippi I don't think!
post #13 of 97 Old 10-06-2013, 02:35 PM Thread Starter
zaxfire69
Halfway through and have 2 different types of plugs. Go figure!
post #14 of 97 Old 10-06-2013, 03:28 PM Thread Starter
zaxfire69
Think I know why I had a miss!
post #15 of 97 Old 10-07-2013, 07:22 PM Thread Starter
zaxfire69
NGK's Gotta GO.....My Jeep will not get to operating temperature. I know it is cool outside, but it should at least get to 210 degrees and it isn't ...Probably around 180. I can lliterally see the gas needle moving. Even with my old plugs I had better gas consumption. Guess I will put new plugs like I had back in there. Were the NGK's suppose to be used with the coil packs our distributer model XJ's
