01 XJ Limited First Time Build - Page 2 - JeepForum.com
post #16 of 110 Old 10-28-2013, 08:07 AM Thread Starter
ParkerXJ
Hm, alright ill keep that In mind! Thanks for the Input
Do you have a rough estimate on price? I know with 2" I won't need longer break lines
3" would've been iffy I think
2001 Jeep Cherokee XJ Limited -3.5" Rubicon Express Super-Ride kit, H4 headlights
ParkerXJ is offline
post #17 of 110 Old 10-28-2013, 08:12 AM
VegasGT
1988 MJ Comanche
It'd be dirt cheap, Id use 2" coil spacers up front (40-50 bucks) and an add a leaf out back. Places like Fat Bob's Garage on eBay usually pair those items together for less than 100 bucks shipped. At 2" you wont need any other supporting mods like taller lifts need. Great way to go for your needs.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #18 of 110 Old 10-28-2013, 08:49 AM Thread Starter
ParkerXJ
Awesome! You've been huge help! What's a max tire size for thqt type? 29?
ParkerXJ is offline
post #19 of 110 Old 10-28-2013, 08:51 AM
VegasGT
1988 MJ Comanche
No problem! And you could comfortably run 30's no problem.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #20 of 110 Old 10-28-2013, 08:57 AM Thread Starter
ParkerXJ
You've been a huge help! Thanks a ton
Could I get away with 1in spacers on the wheels?
ParkerXJ is offline
post #21 of 110 Old 11-02-2013, 09:45 AM
Agility
1997 XJ Cherokee
Just don't buy cheap spacers and make sure you go back and torque them again after a hundred miles.
Agility is offline
post #22 of 110 Old 11-02-2013, 10:18 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I got started about 2 years ago and this is what I did:
3" lift: coils, leaves, shocks
Add-ons: adj. Track bar, longer sway links, 1" shackles(to fight the sag)
Tires: 31x10.50 BFG/AT's
Rims.15x10 w/ -19 offset (about 3.25"backspace)
The one thing I did that most others haven't is upper and lower control arms. This has allowed my front end to make much better use of the added flexibility, and to keep the front axle in it's proper place. Also the stock arms truly act as limiting straps and, due to the angle after lifting, will make the ride a lot rougher.
Brake lines: front lines have enuf extra already, in the front fender well you can pop the rubber grommet out of a bracket to achieve use of this added length. In the rear, I don't exactly recommend this, but I unbolted the T-box from the rear axle (2 years and no broken lines).
This all came to about $1300 not including the tires and rims.
D3<!L!>3D
S8NNG8 is offline
post #23 of 110 Old 11-02-2013, 10:22 AM
Luke95
Ok I'm going to just throw this out here.
If I were to do it as a dd only, I would look at some k1500 shackles and some coil spacers. I'd leave my shocks alone and run 31x10.5 in the bfg all terrain flavor or duratracks. Both are great on road an will handle nice. As far as wheeling I'd do some extended bump stops. Down the road I'd do an Iro double shear trackbar. The factory one sucks!
This is coming from some one who is rocking 3 inches of lift and 34s.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #24 of 110 Old 11-02-2013, 10:39 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
We'll all tell you what's better, better, better. But it's about what you're after from the ground up. I actually ran 31's with no lift for a year. It only worked well due to the backspacing of these Exploder rims.
D3<!L!>3D
S8NNG8 is offline
post #25 of 110 Old 11-02-2013, 10:57 AM
Agility
1997 XJ Cherokee
That looks great!
Agility is offline
post #26 of 110 Old 11-02-2013, 11:02 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
That was forever ago. Now it looks like this.
D3<!L!>3D
S8NNG8 is offline
post #27 of 110 Old 11-02-2013, 11:16 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I did have one issue with the 31's on stock suspension. Any passengers and the back tires would rub. The 1" shackles were the first thing I added to solve that problem. I then found out the shackles I bought for $100+s&h, are identical to Ford Ranger shackles which can be gotten at the jy for way less.
D3<!L!>3D
S8NNG8 is offline
post #28 of 110 Old 11-02-2013, 05:42 PM Thread Starter
ParkerXJ
Yeah I'm debating wether or not buying new leafs or just getting aal's
I'm definitely going to get a shackle, most likely a 1" for, as stated before, sag prevention
Probably won't go through with wheel spacers
ParkerXJ is offline
post #29 of 110 Old 11-02-2013, 06:13 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I see spacers as just another 20 nuts to come loose and cause an unwanted result. I prefer the properly backspaced rims.
Now the AAL will likely sag sooner and worse than a new, longer set of leaf springs, kind of the same concept as replacing the control arms. To lift, you need a deeper arch to the same contact points. This requires a longer spring to be done properly. AAL's try to arch the spring while the distance it goes lays it flat all over again, kind of pointless.
D3<!L!>3D
S8NNG8 is offline
post #30 of 110 Old 11-02-2013, 06:20 PM Thread Starter
ParkerXJ
Yeah, ill most likely end up with a new set of leafs and while at it replace the control arms
ParkerXJ is offline
