-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   01 XJ Limited First Time Build (http://www.jeepforum.com/forum/f177/01-xj-limited-first-time-build-1728194/)
ParkerXJ 10-27-2013 01:49 PM
Hello all!
This is my first time posting and registering but ive been looking and searching the forums for a while now!
im looking to lift my XJ 3" to give it a more aggressive look
but my delima is that I dont know what I may end up needing to do
my jeep is my DD and when I can afford it will put 31s on it
not looking to do Off-road only, but have the option to
I will mainly be driving highway
I know I will need longer brake lines, new shocks/coils
but any suggestions on what I should buy/use?
NOTE: my XJ is STOCK
thank you! and have a great day! :thumbsup:
ParkerXJ 10-27-2013 02:10 PM
Also after doing some research, I've found what I think to be what some of my specs are (taken directly from EricsXJ -Cherokee stock specs)
AXLE: Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01
OR Chrysler 8.25 - 29 spline, 1.21" diameter shafts, 8.25" ring gear, 3" axle tube - used 97-01
DRIVESHAFT:
FRONT: 87-01 XJs (NP231/242 t-case) the front is a "double cardan" two-piece driveshaft with a CV joint at the transfer case end.
REAR: The rear is a one-piece shaft with standard u-joints at both ends. The slip yoke is located on the output shaft of the transfer
case. On 96-01 due to a design change, the slip yoke is external (does not slide in and out of the transfer case).
This slip yoke is covered with a rubber boot.
TRANSMISSION: AW4 - 4 speed automatic, electronically controlled - manufactured by Aisin - used from 87-01
(87-91 models include a Power/Comfort button that adjusts the shift points)
med 10-27-2013 04:15 PM
If I could start from scratch on my jeep again I would just leave it as is and save until I decided what I actually wanted to end up with and had the money to do it right the first time. I know personally how impossible it is to own a jeep and not throw money at it. Start with skid plates or bumpers.
ParkerXJ 10-27-2013 05:12 PM
I know, what im trying to get is a wider stance, lift it at MAX 3" for some added height
like I said, im not looking for extreme off-roading, as it'll be a DD
Just trying to get a feel for what i'll need to do ontop of a lift, like since im not doing much off-roading (and when I do nothing too extreme, very simple) would I need to replace my brake lines with longer ones?
im going to replace the shocks, coils when I lift it, not trying to do a simple shackle lift, if im going to do it I want it safe and to be done right the first time
is there anything else I should do? would I need adjustable control arms? or anything to help my jeep be SAFE while driving, the last thing I would want is to do it crappy and have something happen to me or anyone else
med 10-27-2013 07:02 PM
After a 3" lift you don't necessarily need anything but an alignment. Adjustable lower control arms would help you keep stock castor angle. Stock brake lines worked for me on 3". If you're worried about it get longer ones. Keep in mind not everybody has the same opinion on what's "right" for their jeep.
ParkerXJ 10-27-2013 09:10 PM
yeah understood, for me "right" is the wide stanced slightly taller then stock look for me
I just had brand new brake lines put in, so with 3" I shouldnt be too worried, right?
Trons 10-27-2013 09:34 PM
I would recommend you learn a little more about Jeeps. Knowing what rear axle you have is one of those things you may want to know before you look at ordering a lift. There are plenty of guides, including, if I remember correctly, a sticky in the tech forum. If you're only going about 3" in height, you probably won't need a SYE, so the type of read drive shaft you have isn't important, per se.
As far as wider, it's tough to go wider without changing out the axles. you can improve the look, and make it look wider, by getting wheels with more backspacing, but the increase isn't huge. You might get 1" or so, per side. you can also get a little wider look by putting a wider tire on a narrow wheel. a 31x10.50x15 will look a little wider on a 8" wheel then it will on a 10" wheel (I do no recommend putting that size tire on a 10" wheel).
There are a lot of pictures floating around. Find a jeep that looks like you want yours to look and find out what it takes to get there.
ParkerXJ 10-27-2013 10:04 PM
Yeah Its a learning process for me
I was already planning on a 1in spacer with 31x10.5s on my 15" rims
Just trying to figure out the lift
Agility 10-28-2013 04:46 AM
Your needs sound a lot like mine. I'm at 3" with 31's myself. Here's my experience:
At 3" I didn't have to do anything special to get rolling, just an alignment. After a month or so I installed a 1" transfer case drop but it wasn't necessary. Around the time I installed the TC drop I installed longer sway bar links. For what it costs, I think that's a pretty worthy addition to the lift project.
Retaining a comfortable ride might be a different story. A 3" lift with stock shackles will result in a hard ride as the shackle is more or less vertical. I'm looking at Liquid Iron Industries leaf sliders or HD Offroad no-lift relocation brackets to solve this problem. I'm also shopping for new lower control arms to retain my turning radius with the 31x10.5 tires on stock wheels. I don't have or absolutely need an SYE yet but it's on the list too.
Agility 10-28-2013 05:05 AM
Now that I think about it, I also needed an adjustable track bar relatively soon after I installed my lift. I started to have some minor death wobble issues that I hadn't experienced before the lift. I bought an adjustable double-shear track bar from Iron Rock Offroad, which solved my problem, though I continued to replace components as time allowed.
ParkerXJ 10-28-2013 05:50 AM
Yeah I just want stability and safety and also what I'd described
So I can get away with just an alignment and would possibly need lower control arms, sway bar link and maybe a differential drop?
Ill add new shackles aswell while I'm at it
Thanks for the info :thumbs:
ParkerXJ 10-28-2013 05:55 AM
I'm also looking to add other things like a cold air intake and whatnot to help with HP
But that's after the lift
Agility 10-28-2013 06:14 AM
Originally Posted by ParkerXJ
Yeah I just want stability and safety and also what I'd described So I can get away with just an alignment and would possibly need lower control arms, sway bar link and maybe a differential drop? Ill add new shackles aswell while I'm at it Thanks for the info :thumbs:
The alignment is an absolute must. You may even need the adjustable track bar to get it aligned properly.
You don't want a differential drop (which probably isn't a thing), you want a transfer case drop. A lot of people will tell you that the TC drop is a temporary fix while you save up for an SYE. Whether that is true at 3" or not, I don't know.
Since you want a wider stance you will be needing new wheels so you might not need lower control arms at all.
ParkerXJ 10-28-2013 06:32 AM
Awesome! Thanks so much! Like I said I've read a lot on the forums but am no way a mechanical expert or even xj, but its all a learning curve! Just trying to get a feel for what I'm going to be getting into
Probably going to replace the coils too
And also looking for different rims
VegasGT 10-28-2013 07:03 AM
Honestly if DD'ing it with occassional offroad use is the plan, I would just do a 2" budget boost lift and 30x9.5 tires. That will give it a tougher look without any real side effects or rubbing issues. If you are wanting more from that setup, put the money toward a locker, add recovery points, skids.
If (when) I pick up a 2nd XJ to be a DD that is my intent. Keeping it simple is the name of the game on a DD.
The time now is 04:55 AM.
