Quantcast Wrangler, no battery power when it rains - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Wrangler, no battery power when it rains
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 04-09-2009, 05:49 PM   #1
slaights
Jumping in to start the Jeep, it will not start. No power/no crank/no lights. I get only power to the stero deck, but it has a separate power cable to amp/etc...
Then after not starting, if I keep trying, it will eventually provide power to start up, and its good until I turn off the engine. Anyone ever see this happen? Any thoughts?
-scott
slaights is offline   Reply With Quote
Old 04-09-2009, 05:59 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Remove, clean, inspect, and firmly reattach all the wires to the battery, alternator, and starter. Repair or replace any defective cable and connectors. Do the same for the smaller ground wires from the battery and engine block to the body/frame.
You symptoms are typical of a loose or dirty power connection.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 04-10-2009, 12:38 AM   #3
flexsaharatj
2004 VJ
did you install any aux lights?
possible that your connections aren't covered and rain is getting on them?
WTB: 98-04 Jeep TJ Wrangler, miles under 120k, I6, manual. Lifted a plus, let me know what you have!! Looking to spend >$5000
2004: Nissan Xterra: SOLD
WJ: Lemon Dealer bought back
Sold: 97 Sahara TJ
Firefighters Jeep Club
flexsaharatj is offline   Reply With Quote
Old 04-10-2009, 12:16 PM   #4
slaights
I cleaned all contacts and jeep now has power, for now. The terminals and all other contacts seemed to be fine, with very little corrosion.I have a strange suspicion this didnt fix the problem, only prolonged it.
I forgot to mention in my first thread that the odometer has displayed in the past, "no bus", but not during this recent incident. I have this odd feeling that this is related in some way. I read some other posts concerning this, and have not started to tear out the instrument panels to tighten the connections...thats because the rain should be going away and this only seems to happen when it raining.
Old 04-10-2009, 03:11 PM   #5
NYCJohn
2009 JK Wrangler
Check your grounds. Make sure your ground wires are connected and have a good connection. If you offroad something may have come loose or got yanked off. There are a number of these however they are typically bolted to the frame or metal part of the Jeep and are shielded (covered in black insolation).
NYCJohn is offline   Reply With Quote
Old 04-10-2009, 05:58 PM   #6
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
....Jumping in to start the Jeep, it will not start. No power/no crank/no lights......
No bus is a separate issue. No bus is either a bad connection behind the instrument panel and the Jeep runs, or the Crank Position Sensor (CPS) is failed and it will crank and crank but never run.
PM me for details
Glock Forum
