Wranger was in a crash...how bad is it? - JeepForum.com
post #1 of 31 Old 01-15-2010, 05:53 PM Thread Starter
oldguy
Some one pulled out in front of me. How bad does it look? The fender is pushed into the body about 2" bit both door open and close with no problems and no difference in body gaps.. The rad. shroud just barley touches the fan and there are no leaks. The wheels look to still be aligned, but I want that checked out real good. Let me know what you think.
oldguy is offline
post #2 of 31 Old 01-15-2010, 06:45 PM
champelite210
Looks like a grill, new tube fenders, bumper and maybe a hood. can't tell. Easy fix.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #3 of 31 Old 01-15-2010, 08:24 PM
Mark05059
iffn its the other guys fault there is alot more damage then what it looks like... if its your fault then its not too bad
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 31 Old 01-15-2010, 08:43 PM
IBreakStuff
put it on a frame machine and get it checked, it looks like the passenger side tow hook is aiming down and since that bolted to the frame that might have that tweaked down a little.
make sure they check the drive line also, put it on 4wd and make sure nothing is making noise.
02 Wrangler X(His)
07 Wrangler X(Hers)
IBreakStuff is offline
post #5 of 31 Old 01-15-2010, 10:42 PM
Mud-Hunter
Yep mine is getting new frame but I hit black ice and hit a concrete barrier head on at 35mph.
Don't assume it is OK and if it was their fault use any and all resources to ensure integrity. After all it is your girl. Good luck.
Mud-Hunter is offline
post #6 of 31 Old 01-15-2010, 11:58 PM
trw
2011 JK Wrangler
your main body tub looks slightly buckled just below the cowl panel, depending on how bad it is, you might be looking at a new body tub which requires the entire Jeep to be disassembled. Other then that, I'd be most worried about the frame.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #7 of 31 Old 01-16-2010, 11:25 AM
mgaither0
if its your fault hit the junk yard. Buy a hood, bumper, grill, and a fender and fender flare. Of now is a new excuse to buy aftermarket bumpers fender flares and so on. Could get the stock parts at the junk yard at most 250 or so. If its the other persons fault then have a shop check it all out.
mgaither0 is offline
post #8 of 31 Old 01-16-2010, 11:27 AM
mgaither0
should be just all blot on parts
post #9 of 31 Old 01-16-2010, 12:40 PM
wTheOnew
Also look at the anti-sway bar on the left compared to the right. That makes it look even more like the frame is bent down on the passenger side.
Georgia Institute
of
Technology
wTheOnew is offline
post #10 of 31 Old 01-16-2010, 09:38 PM
all_clear
Take a look at my re-build. That's about the same damage mine had. My bags were blown and the frame was tweaked. Tub corner needed pulled but its a jeep parts are replaceable... even frames and tubs.
I'd say that's pretty minor myself. As for the frame there are holes in the frame that you can take a tape measure to and see if it's off. My frame work and tub pull was under $500.
Measure in an X form from front right to rear left, front left to right rear (just need to measure the front portion of the frame, just look for the holes)
I hand tweaked the hood back to shape. The corner shows a little dent up close but who cares it's a jeep and hoods aren't cheap.
Tub can be pulled easily also. Might need some body mud to smooth it out but an easy fix. Just pay to have the tub pulled, you can mud and sand it yourself.
If i could do it again (which i hope to do) I'd buy tube fenders rather then pay $150ish for a reg old fender. Guess that depends on your budget.
PM me if you need help. I can answer a few questions you might have.
Oh and get your tape measure out and check the alignment yourself. It's easy.
Nathan
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
post #11 of 31 Old 01-17-2010, 11:20 AM
JEEP_GREEN_4DR
2009 JK Wrangler
Really? No one's said it yet?
It'll buff out.
JEEP_GREEN_4DR is offline
post #12 of 31 Old 01-17-2010, 07:19 PM
AustinTexasXJ
1987 MJ Comanche
It'll buff out.
damn I was about to
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #13 of 31 Old 02-03-2010, 05:07 AM Thread Starter
oldguy
TOTALED I'll find out today what they think it's worth. Time to look for a new one.
oldguy is offline
post #14 of 31 Old 02-03-2010, 07:28 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Sorry to hear. That is what always scares me as I drive in heavy traffic, and is why my TJ is not my daily driver.
Best wishes on finding a new one.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #15 of 31 Old 02-03-2010, 08:24 AM
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
Thats totalled? Tube fenders, and a winch bumper, fixed. Why did they say its totalled?
Rock Krawler Suspensions
mikebigh is offline
Need help with new 1993 Jeep wranger 4cy!!!! rdclark1 YJ Wrangler Technical Forum 8 03-25-2009 07:35 PM
05 Wranger Install with 791VX Rugby_3 TJ Wrangler Technical Forum 5 01-27-2009 10:04 PM
Opinions on Wranger for DD? JohnsonA89 TJ Wrangler Technical Forum 70 06-09-2008 06:59 AM
98 Wranger, Go for it? kosrebelyell TJ Wrangler Technical Forum 9 12-05-2006 07:39 PM
New 99 Wranger Sahara Owner DutchmanAZ TJ Wrangler Technical Forum 7 08-27-2004 01:05 PM
