Would 35's fit? - JeepForum.com
post #1 of 8 Old 07-07-2013, 09:47 PM Thread Starter
RedRocks
Would 35's fit?
Right now I have 33's on my jeep, but im not sure what size lift is on it. Does it look like 35's would fit on without destroying my fender flares?
RedRocks is offline
post #2 of 8 Old 07-07-2013, 10:26 PM
Ljcrawler05
What do you do with the jeep?
If it is only a highway driver they may fit but you may have rubbing even still
If it is taken on any unstable ground you may destroy your fenders, but if you were to offroad even with your current setup with 33s, unless you've got some bump stop extensions you probably would rub with the front sway bar disconnected.
There really isnt a definite answer for you without knowing some of the specs of your jeep and intended use
Also, what gear ratio are you running?
Basically all stock gearing in jeeps is not low enough for 35s... but thats imo
Ljcrawler05 is offline
post #3 of 8 Old 07-08-2013, 05:17 AM
bogleparsons
Holy mother of tire shine products!
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #4 of 8 Old 07-08-2013, 12:55 PM Thread Starter
RedRocks
Im pretty sure its just stock. How do you tell?
RedRocks is offline
post #5 of 8 Old 07-08-2013, 12:56 PM Thread Starter
RedRocks
Ya, I Had to shine them up, for a fourth of july parade it was in.
RedRocks is offline
post #6 of 8 Old 07-08-2013, 01:07 PM
JBTJ
35's with stock gears and brakes WILL suck. It will be a drag to drive and the girls will laugh at you.
JBTJ is offline
post #7 of 8 Old 07-08-2013, 01:12 PM
biffgnar
biffgnar's Avatar
http://www.jeepforum.com/forum/f9/fa...-ratio-615380/
biffgnar is online now
post #8 of 8 Old 07-08-2013, 07:37 PM
tyvanwie
With proper bumpstops they won't
Sent from my iForum using JeepPhone
tyvanwie is offline
