Winch safety and questions. - JeepForum.com
post #1 of 11 Old 12-03-2011, 12:04 PM Thread Starter
bella mia
I saw a winch solenoid stick and do thousands of dollars damage .
1. Does anybody have any quick disconnect power Ideas ?
2. What is the difference between a lifting winch and a pulling winch ?
3. Can you over lubricate the gear box on a winch. I see automatic self holding brake in most of the info and was wondering if lubrication might make them slip ?
bella mia is offline
post #2 of 11 Old 12-03-2011, 04:29 PM
KKiowaTJ
If it were to happen to me, Id want to kill the power to everything and stop it dead in its tracks. All that would take is a battery cut out switch just like you would install to slow up thief's.
MOPAR!
KKiowaTJ is offline
post #3 of 11 Old 12-03-2011, 04:57 PM
222Doc
222Doc's Avatar
I used the kind that has the red removible switch handle. No handle no power. Same type used on thetrack. Two reasons I do, call me paraniod; If any thing goes bad goes bad on the winch, the winch has remote control, if someone else has the same or perhaps a random signal that is the same. Might not be possible who knows, better to have if off and off.
222Doc is online now
post #4 of 11 Old 12-03-2011, 06:13 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
post #5 of 11 Old 12-03-2011, 09:43 PM
hndswthtshdws
You could also use a heavy duty plug. Yes it will arc if you disconnect it under load. I would have more peace of mind ripping a big plug apart to kill the winch than I would flipping a switch. I know a winch is unlikely to fail and the switch is even less likely to fail, but nothing beats just ripping wires apart.
You could wire a set of booster cables to said plug. Plug in your booster cables and use on whatever.
-A hoist will not have a free spool option.
-A hoist has a positively locking brake system compared to a dynamic brake system. Think of the winch as having a hand brake and the hoist as having a P (auto tranny).
-Hoists typically have a narrow spool which wont bind up, winches typically have a wide spool which can bind up when side winching. Wide spools fit on bumpers, narrow spools do not.
-Hoists have to adhere to a ****load of safety standards.
I'm not sure how winches are rated. To me an 8000lb pound winch should be able to apply 8000lb of tension in the winch cable, meaning it would stall when trying to lift 8000 lbs. Should be able to lift 7999.99 pounds. Not sure if thats actually hows its done or not. In the movie "the gods must be crazy" the winch served very well as a hoist.
hndswthtshdws is offline
post #6 of 11 Old 12-03-2011, 11:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Check out 12voltguy.com. He puts together some disconnect options as well as some in cab controls. Worth checking out his site.
Luck Favours The Prepared
Anticanman is offline
post #7 of 11 Old 12-04-2011, 12:38 PM
wushaw
Rockin jeep
wushaw's Avatar
Which one are you talking about? I have his in cab winch controls.
wushaw is offline
post #8 of 11 Old 12-04-2011, 02:28 PM
jay-h
you could use something like this (and even leave it in the OFF position when not in use)
http://www.summitracing.com/parts/PCO-5575PT
jay-h is offline
post #9 of 11 Old 12-04-2011, 02:29 PM Thread Starter
bella mia
I will research this 2 night but For guys with two batteries I think you can make a dedicated two wire circuit with the batteries in series and increase your no load line speed. This can be for no load only but I think I can draw the circuit 2 nite and make it for no load increased line speed both in and out. After Hurricane Ivan we had a lot of power problems and I made a similar circuit to switch a 110 volt AC refrigerator to run on 12volt DC batteries.
post #10 of 11 Old 12-04-2011, 03:04 PM
2jhanna
My input is kind of off subject a little here but still important. I've installed winches on F550 4wd fire dept brush trucks. I never liked having raw unswitched unfused hi current battery power running to the front (and rear in 1 case). What if you hit a tree stump, rock, or anything that could pinch this hi current cable to chassis ground. 300-400 raw unfused amps of power being shorted to ground in not a pretty site.
Having a main switch in the red cable like the link above, mounted close to the battery is, in my opinion, a must.
jhanna
denton county, tx
2jhanna is offline
post #11 of 11 Old 12-04-2011, 03:30 PM
wushaw
Rockin jeep
wushaw's Avatar
That one would be right at the Max of my which amperage rating.
wushaw is offline
Winch safety. bella mia YJ Wrangler Technical Forum 1 04-21-2010 09:09 AM
Winch safety. bella mia Wrangler General Discussion 0 04-21-2010 08:35 AM
Safety Questions AlayGtr TJ Wrangler Technical Forum 6 01-04-2009 08:29 PM
Winch questions ski313 JK Wrangler Technical Forum 20 10-02-2007 07:51 PM
Winch Questions holyearth TJ Wrangler Technical Forum 5 05-30-2007 09:41 PM
