Wildlife will die for this... - JeepForum.com
post #1 of 44 Old 12-01-2010, 09:39 PM Thread Starter
mikey8882
So I just got the Jeep back from the shop today. Got in the other day, turned the key, it cranked but never started up. My (out of town) mechanic brother-in-law eventually diagnosed it as a fuel-pump related issue. After having it towed to the shop and having them look into it further, I got some good news and some bad news. The good news was that the fuel pump was fine and I wasn't going to have to pay a fortune for a new one. The bad news was that the electrical wire leading to the pump was severed, and it appeared that something had chewed through it. In other words, some hateful mouse or squirrel in my back yard owes me $250 for the repairs.
Has this happened to anyone else? And if so, did you also get the urge to buy a shotgun and rid your yard of anything that crawls like I did?
mikey8882 is offline
post #2 of 44 Old 12-01-2010, 09:43 PM
MrRage
$250 to splice the 4 or so wires that run to the fuel pump sounds a bit high, but I guess thats mostly labor. Still sucks though. I had the engine wiring harness catch on fire, does that count?
MrRage is offline
post #3 of 44 Old 12-01-2010, 09:52 PM
sxysouthtx
I say you should commit Mouse/squirrel genocide. Just a thought.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #4 of 44 Old 12-01-2010, 09:54 PM
Imped
Imped's Avatar
Wow. Learn how to do your own work. A fuel pump is an easy replacement. Splicing a few wires is easy and would have cost you about $5 and 10 minutes.
OlllllllO
IndyORV
Imped is offline
post #5 of 44 Old 12-01-2010, 09:56 PM Thread Starter
mikey8882
I know it was probably an easy fix, but I'm about as mechanically retarded as it gets with cars. Getting into possibly dropping the fuel tank isn't really something I wanted to try to learn on the fly, especially since it's 20 degrees outside right now.
post #6 of 44 Old 12-01-2010, 09:59 PM
Hussler
1992 XJ Cherokee
Theres so many things wrong with this quote its frightening.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #7 of 44 Old 12-01-2010, 10:03 PM
Jason
^This. $250 for splicing a few wires blows. And a shotgun is really the wrong tool for rodents.
Jason is offline
post #8 of 44 Old 12-01-2010, 10:07 PM
Ezalycasaid
Originally Posted by hussler View Post
theres so many things wrong with this quote its frightening.
x2
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #9 of 44 Old 12-01-2010, 10:08 PM Thread Starter
mikey8882
Well, by all means, please enlighten me.
post #10 of 44 Old 12-01-2010, 10:14 PM
DstroyrOfWrldz
I imagine a good portion of that was diagnosis and locating the wiring problem.
I haven't had it happen, but my brother had a rat or mouse get under the hood of his BMW and chew up a bunch of wiring harness. I think that bill was nearly $800.
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is offline
post #11 of 44 Old 12-01-2010, 10:16 PM
dmc_rrt
My brother was finishing a fly in forestry camp after 2 weeks. Helicopter drops him off at his truck, which is still 80kms from the nearest hick town. Him and his crew where all pumped up to head back to civilization to tie one on, only to find a porcupine had gutted all his lines under the hood. The poor little bugger was still under the truck. No need to say more.
dmc_rrt is offline
post #12 of 44 Old 12-01-2010, 10:20 PM
Hussler
1992 XJ Cherokee
-I know it was probably an easy fix
-I'm about as mechanically retarded as it gets
-car
-isn't really something I wanted to try to learn on the fly
-it's 20 degrees outside right now.
You'll get as much out of it that you put into it. A Jeeper can only survive if hes a wrencher.
Hussler is offline
post #13 of 44 Old 12-01-2010, 10:20 PM Thread Starter
mikey8882
Yeah, I'm sure that almost my entire bill was for diagnosis and labor, as the wiring was probably very inexpensive.
post #14 of 44 Old 12-01-2010, 10:21 PM
RogueSpear2023
My neighbor had a chipmunk climb into his engine and try to build a nest, it chewed through the air filter, he built his nest on top of one of the pistons. When he tried to start the car after it sat in his garage for 3 days, bad things happened. The end result was the motor needed to be rebuilt, he was not happy. They found pieces of the nest when they tore the motor down.
Also my uncles cabin had a squirrel get locked in over the winter, and in the squirrel attempt to escape he did 100K worth of damage to the window sills and doors and door frames, and other wood parts of the house. squirrels have now become an endangered species around his cabin.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #15 of 44 Old 12-01-2010, 10:29 PM Thread Starter
mikey8882
I feel you on this, I really do. The only problem is this- my Jeep is my only vehicle, and I have a full time job that doesn't involve spending hours at a time working on that Jeep. This issue wasn't one that I could address after work in my driveway. As I said, I'm not exactly a mechanic and - even though it might be an easy fix for you, it wouldn't be for me. And I mentioned that it is cold here, because, yes... it is cold as balls here.
And sorry about the "car" thing... it's a learning process for me (I'm a first generation Jeep owner, wasn't born into this thing).
fail , fuel , pump
