Why my TJ can't go 100 mph - Page 3 - JeepForum.com
post #31 of 85 Old 06-11-2014, 02:30 PM
Ben
Originally Posted by IlliniJeeper View Post
Around here, the elevation changes I'm talking about necessitate truck lanes. I take issue with the implication that I've neglected maintenance on my rig.
If you had your profile filled in, the world would know what you meant by "here".
But you don't.
Ben is offline
post #32 of 85 Old 06-11-2014, 02:40 PM
329892 - Deactivated
Guest
In Texas where he's from it's called driving normal.In Va it's loss of license for 30 days.To the OP,go to court and tell them you didn't know the PO forgot to change the speedo gear for the larger tires.The worst the judge can do in Texas is take you out back and shoot you.
In BC and Alberta, Canada it is an instant road side 30 day suspension, 7 day car impound plus the fine, plus towing, plus storage. .......
And they leave standing on the shoulder... with your family if you were stupid enough to do 100mph with kids in the Jeep
329892 - Deactivated is offline
post #33 of 85 Old 06-11-2014, 02:41 PM
IlliniJeeper
But you don't.
Central IL. South of the glacial extent and carved by half a dozen rivers. Hell of a lot hillier than Plano. The problem is that "here" has a pretty big difference in landscape. Over by Champaign, an anthill constitutes a significant elevation change. Over here further west, it's quite a bit hillier.
'98 Jeep TJ Sport
IlliniJeeper is offline
post #34 of 85 Old 06-11-2014, 02:42 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yes, I'm talking 5th gear. If you're shifting down into 4th to build up speed, you kind of have to know that you're flogging it between the actual need to down shift and the racket that the drivetrain will be making. Hard to make the argument that you were just cruising along and "accidentally" got to 90+ mph in 5th.
Its also hard to make the argument that a TJ cannot do 80-90+ MPH.
You saying that your TJ has issues keeping speed above 80 MPH while cruising in 5th gear uphill does not support the argument either. It was kind of misleading how you stated this previously. This post here:
Yes, that's exactly what I said. With 3.55s and 33s, your issue isn't gearing, it's horsepower. I doubt that 17 year old 4.0 has the guts to hit 80. My 16 year old 4.0 with 33s and 4.56s has issues keeping speed above 80 with any kind of elevation change.
Wheelin98TJ is offline
post #35 of 85 Old 06-11-2014, 02:51 PM
IlliniJeeper
Fine. There's a reason why I don't have a ****ing clue about any this: driving a lifted TJ over 80 mph is borderline suicidal. I don't even take my TJ onto the interstate (70 MPH speed limit) when I've got my kids in the car because I don't feel that it's safe.
'98 Jeep TJ Sport
post #36 of 85 Old 06-11-2014, 03:01 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Was it a radar or a laser ticket?
To best determine how to defend against a speeding ticket that you have received and are disputing, you should speak with an attorney who is experienced in dealing with speeding violations. Because of the differences in types of speeding tickets, and the complexity of the laws, it can become very difficult to beat a speeding ticket, and you'll want a qualified and knowledgeable lawyer on your side.If you lose, your insurances rate like everything else is going to be greatly impacted.Does Texas offer traffic school? Here in Ca. it does, you still will pay the fine take the school which costs but at least it doesn't go on your driving record,so not insurance hike. I believe it's only offered every 18 mos. with no tickets in between.Good luck!
GOLENJEEPTJ is offline
post #37 of 85 Old 06-11-2014, 04:58 PM
99SprintST
I regularly drive my '01 with 130k on it over 80-85 mph on the interstate. I do 300-500 mile days 6 days a week in it. Going west on I-70 out of Denver up Floyd Hill maintain 80 no problem. For you flatlanders out there, this is a Rocky Mountain version of a hill. Runaway truck ramp on tge downhill side and creeper lanes going up. 373 gears, 31" MTR Kevlars that are much heavier than most tires, and full Rokmen armor plus a winch. Will it hit the ton? Yep. No problem. Recommended? Nope. But it certainly will go in excess of 100 without a tail wind or a downhill to make it happen.
Sent from my Galaxy Note 8 using JeepForum
99SprintST is offline
post #38 of 85 Old 06-11-2014, 05:12 PM
bisleywrangler
I drove my 97 4.0 with ax15 and 33 tyres at an indicated 70 (uk speed limit) for. 200 miles only later to realise that the Speedo was set for 28" tyres, guessing was doing around 90?
bisleywrangler is offline
post #39 of 85 Old 06-11-2014, 06:08 PM
danielbuck
1946 CJ2
Originally Posted by billiebob View Post
Agreed, And the cop will say you were runnin" downhill with tailwind. Your only hope is proving the equipment the cop was using was faulty!
street name, direction of travel, and time of day are probably on the ticket. Weather reports can be found online, to find the general direction of the wind.
I bet you could do 100 in a jeep. My 70 year old willys will do better than 65, and it's only limited because that's as fast as the motor will spin. My TJ I've done 90 while passing someone, it'll go faster, but not that I'd really like to.
danielbuck is offline
post #40 of 85 Old 06-11-2014, 07:16 PM
Trespasser
In 2002 I got a ticket doing 100mph on the NY Thruway in my '98 Sahara. And I WAS doing 100, for about 30 minutes until I got caught. That Jeep was topped out: I had it floored in 4th gear (5th would actually lose power and slow the Jeep down a bit). On the downhills the needle went past 100 to maybe 105 range.
I dont drive like that anymore, and my current TJ starts feeling iffy when I get over 55mph... At 100 it would self-destruct.
Trespasser is offline
post #41 of 85 Old 06-11-2014, 07:25 PM
Wheelin98TJ
JEEP FREAK
Strange that you were able to get the speedo to exceed the typical 96 MPH speed governer.
My 98 would not go faster than the speedo showing 96 MPH.
I wasn't actually traveling this speed, this was shortly after a regear and I still had the incorrect speed gear.
I was only doing about 60 MPH, but since the speedo was showing 96, I couldn't travel any faster. Those few days with the wrong speedo gear sucked driving the highway to work.
Now that I have a motor swap, different PCM, and different speedo, I am limited to 117 MPH on the speedo.
post #42 of 85 Old 06-11-2014, 07:48 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
That sucks. I feel pretty damn safe in my Tj rolling 80+.
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider TJ on 40s.
NYGLT56 is offline
post #43 of 85 Old 06-11-2014, 07:50 PM
NYGLT56
NYGLT56's Avatar
Strange that you were able to get the speedo to exceed the typical 96 MPH speed governer. My 98 would not go faster than the speedo showing 96 MPH. I wasn't actually traveling this speed, this was shortly after a regear and I still had the incorrect speed gear. I was only doing about 60 MPH, but since the speedo was showing 96, I couldn't travel any faster. Those few days with the wrong speedo gear sucked driving the highway to work. Now that I have a motor swap, different PCM, and different speedo, I am limited to 117 MPH on the speedo.
Yup. I was limited to 50 once. That sucked. But I also found you can bypass the limiter by disconnecting the speedo gear. Hit 112 on a top speed run on a closed course. And man it was hard.
2014 TJOTY Winner
NYGLT56 is offline
post #44 of 85 Old 06-11-2014, 10:01 PM
joe108
You guys going anywhere near 100 in a jeep are either suicidal or just young and indestructible , slow down, get a sports car, then getting a 100mph ticket won't be so hard to take
joe108 is offline
post #45 of 85 Old 06-11-2014, 10:21 PM
jimk403
2009 JK Wrangler
I don't know, 2 of ours will do 100 or more with absolutely no issues. The JK does 100 easy, then it cuts out because I have not raised the speed limiter. The '90 XJ has been to 110.
If you(generalization) don't feel safe driving your Jeep fast, maybe you should fix whatever is wrong with it.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline
police brutality , specs , speeds , tj
