where to mount a Cb radio? - JeepForum.com
post #1 of 19 Old 08-19-2008, 04:29 PM Thread Starter
Kevinstravels
someone gave me a old Cb they didnt want any more and i was wondering where can i mount it so its out of the way, but still accessible. and advice or pictures would be apreciated!
"Im So Fast that last night i turned off the light switch in my hotel room, and was in bed before the room was dark."
Kevinstravels is offline
post #2 of 19 Old 08-19-2008, 04:53 PM
chupacabrah
chupacabrah's Avatar
i mounted mine kind of under the radio
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #3 of 19 Old 08-19-2008, 04:59 PM Thread Starter
Kevinstravels
thats where i was thinking too. where did you put the antenna? i was thinking about putting mine on the back bumper but im afraid the antenna will slap and scratch my hard top and back glass
post #4 of 19 Old 08-19-2008, 05:04 PM
chupacabrah
i put the ant on the thing that the spare would hit. i think i have a pic
-Jon
post #5 of 19 Old 08-19-2008, 05:31 PM
DUKENEUTRON
mine is mounted on top of the dash over the little storage area, my mike hang's on the rear view. My antenna is on the passenger side front bumper I havent hit it yet.
DUKENEUTRON is offline
post #6 of 19 Old 08-19-2008, 07:02 PM Thread Starter
Kevinstravels
those are good ideas, i think i might mount mine under my radio. i hooked the cb up a while ago and it turned on but no sound or anything and the mic wouldnt make any noise. you think its broken or did i do somethign wrong
post #7 of 19 Old 08-20-2008, 05:16 AM
chupacabrah
it's not supposed to make any noise unless it's receiving a signal
best way is really to get someone else w/ a cb and test it out, make sure you can transmit and receive.
-Jon
post #8 of 19 Old 08-20-2008, 05:27 AM
JerseyDoug
Can I go home now?
I hope you have the ant connected before using the mic. Otherwise you may damage the radio. Perhaps you have the squelch set too high? Back it off, you should at least hear some static with it turned all the way down. At least I do.
Good luck.
JerseyDoug is offline
post #9 of 19 Old 08-20-2008, 05:39 AM
chupacabrah
Good luck.
^^ he's right, i dont know what I was thinking.
check the squelch.
It'd be good to have an SWR meter too ( about $30) to measure that so you don't blow the radio up. if you have an adjustable ant, anyway. if not then it doesn't really matter too much
-Jon
post #10 of 19 Old 08-20-2008, 08:43 AM Thread Starter
Kevinstravels
i checked everything and it turns out the internal speaker is fried and i cant get any audio from it. its about 20 years old anyway. i'm gonna set out today and go to a few pawn shops and see if i cant find myself a new one. My antenna mount is magnetic and the only place i can seem to put it is on the back right bumper but im afriad of it slapping my hard top and glass at highway speeds. does anyone else have it set there or is there another way i can mount it to the side of my bumper?
post #11 of 19 Old 08-20-2008, 09:00 AM
chupacabrah
you could just put it on your wheelwell. wont really get great reception...
or maybe on the front of your jeep, on the frame. or maybe even on the hood or something.
I wouldnt really leave a magnetic one mounted when not offroading though, could fly off on the highway possibly.
-Jon
post #12 of 19 Old 08-20-2008, 10:35 AM
jbramble24
Here's where I mounted my radio shack cheapie in my 05. My antenna is mounted on my rock hard 4x4 parts rear bumper.
jbramble24 is offline
post #13 of 19 Old 08-20-2008, 03:31 PM Thread Starter
Kevinstravels
well my cb searching all went to crap, i looked and couldnt find a Cb at pawn shops (that were worth buying) Did any of you just get your stuff at radio shack, because if you did can you let me know what antenna and stuff to get because every one i have talked to about the subject around here think they are obsolete. i just want a radio and antenna that will get good reception, not the most expensive of the bunch. ha, i didnt think this would be a problem when i got the first radio. thanks guys for the replys!
post #14 of 19 Old 08-20-2008, 03:43 PM
Grt_Ape
Until I put a sport cage in, I'm using the MP mount from http://www.jeepoutfitter.com/. Here's a pic from their website:
Chris
2006 LJ Rubicon
Grt_Ape is offline
post #15 of 19 Old 08-20-2008, 05:23 PM
chupacabrah
my cb is a uniden. cheapie, just like the radioshack one listed above. works good when i need it.
my antenna i think is a firestick or something similar. 5 or 6 ft whip, adjustable on the tip. i think they go for like $25.
I got all my stuff at a local cb shop
-Jon
CB Radio Mount omnicitadel JK Wrangler Technical Forum 4 05-01-2008 11:22 PM
Where to Mount the CB Radio??? IMYY4U JK Wrangler Technical Forum 5 01-24-2008 04:16 AM
CB radio and mount adstroop YJ Wrangler Technical Forum 5 01-08-2008 06:18 PM
cb radio mount tjwrangler911 TJ Wrangler Technical Forum 20 10-06-2007 06:25 AM
cb radio mount panhd TJ Wrangler Technical Forum 6 03-15-2002 04:19 PM
