When offroad, does it really bounce so much? - JeepForum.com
post #1 of 19 Old 06-20-2008, 07:04 AM Thread Starter
esad_b
Well ive had my TJ now for 2 years.. all stock except 30" M/T tires. My question is when i go offroad the thing bounces around so much it drives me crazy, i went into a little trail just the other night and i felt like turning around because i was being thrown in the seat.
Im just wondering is that normal? Because my Jeep seems to be stiff on/off-road. Everytime i see another Jeep and if they hit a bump it seems like they dont get thrown around like that or that they take the hit a lot better than me.
I really dont understand what the issue is, i know im not driving a Cadillac but whats up with the stiff *** suspension? Also what would be a recommended PSI for my tires? Their Yokohama Geolandar M/T + im running them around 29 PSI.
esad_b is offline
post #2 of 19 Old 06-20-2008, 10:29 AM
ONEMORE2
ONEMORE2's Avatar
With your tires when off road get the PSI around 18 it will help, I wouldnt go any lower or you may pop a bead.I have 32"s and when of road I run around 12-15 psi
88yj, incubus off road wheels,32"tsl radial super swampers,2.5" pro comp lift ,kc lights,rock lights,8000lb.mile marker winch,best top bikini top,nutterbypass,lock right locker in the rear,TJ flares,poison spyder rock rails,home made front flat fenders,Skyjacker nitro 8000 shocks,procomp rear bumper,CB.more to come.
92yj,black with flame job.I have now added a 2003 wrangler,2"BB,dick cepek wheels ,trail armor all four corners,33" BFG-AT's.life is good.
ONEMORE2 is offline
post #3 of 19 Old 06-20-2008, 10:51 AM Thread Starter
esad_b
Well i would hate to pop a bead, i really dont think i will even go close to 18psi then, maybe ill stay above the 20's mark. Is there still a chance of popping a bead?
esad_b is offline
post #4 of 19 Old 06-20-2008, 10:57 AM
Morgen251
2010 JK Wrangler
You'll be more than safe around 12-15 PSI, without risk of popping a bead.
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder.
BUILD:
Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines
WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery
Morgen251 is offline
post #5 of 19 Old 06-20-2008, 11:17 AM Thread Starter
esad_b
more safe at 12-15psi than like 24psi? Is that what your saying?
esad_b is offline
post #6 of 19 Old 06-20-2008, 11:21 AM
00jeepsahara
00jeepsahara's Avatar
At 15 psi you will not pop a bead, just wondering though, hows your driving style? do you go fast through trails, or what kind if trailing are you talking about?
2000 Jeep Wrangler Sahara
113" Wheelbase
42 Iroks
17" Allied Beadlocks
D60/14BFF
00jeepsahara is offline
post #7 of 19 Old 06-20-2008, 11:36 AM Thread Starter
esad_b
Im extremely slow, take my time. and make sure i dont damage anything on my baby lol.
Well this trail was pretty beat down as in others driven on it so it was fairly flat but it was still bumpy as hell and that's why it was driving me nuts because i could of just imagined what would it have been like it was rocky. Most trails i try to go into dont involve rocks anyways its all dirt/mud but still bumpy
esad_b is offline
post #8 of 19 Old 06-20-2008, 03:58 PM
Morgen251
2010 JK Wrangler
No, I said you will be MORE THAN SAFE at 12-15 psi, not MORE SAFE. You'll have much better traction at lower PSI, and your risk of slipping a bead is miniscule.
BUILD:
post #9 of 19 Old 06-20-2008, 09:19 PM
sahara tj
You'll be fine at 15 psi. Just make sure you have a way of airing up before hitting pavement. If not keep it under 50 mph.
sahara tj is offline
post #10 of 19 Old 06-20-2008, 09:26 PM
raskull
raskull's Avatar
I air my tires down to 8 psi when off road, and it helps a lot with traction.
I only pop a bead about once every 5-6 trips out (if that), and I have all the supplies to get it re-seated.
The best thing you can do for offroading is to buy a cheap air compressor, mount it under the hood, and run lower pressure on the trail.
The lower the better, period. I stick to around 8 because if I run any lower I blow a bead more often than not. I air down to 5-6 for really tough climbs, but generally stick to 8. The air compressor I run cost me about $125 or so. That comes with a nice holding bag, air line, and a few attachments for airing up soccer balls, etc.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #11 of 19 Old 06-21-2008, 02:54 AM
Moses2564
I have a tire deflation chart, that goes by tire size and gross vehicle weight, that states if you are running 30x9.50R15, and ~3000-4000lbs. you should be running anywhere from 10-12psi off road.
2000 Solar Yellow TJ
2000 Ford F250 Super Duty
2006 Volvo S40
1997 Arctic Cat ZRT 600
Moses2564 is offline
post #12 of 19 Old 06-21-2008, 04:34 AM
Bigboyky
Air down it's the way to go. I've had 4x4's for a very long time think I bought my first in 1989. I never aired down in the bigger trucks. The only time I've had my jeep out I didn't. No way of pumping them back up. But you can bet I will this time, my kids bought me a compresser to mount on the jeep.... I'm going to run between 10 & 12.
Bigboyky is offline
post #13 of 19 Old 06-21-2008, 05:22 AM
Kiwi Jeeper
After airing down, try disconnecting the fron sway bar as well and see how much more fun it becomes. I never drive at street pressure offroad, my compressor is hard mounted in the engine bay. Normally run between 12 / 18 psi (depending on the conditions).
Kiwi Jeeper is offline
post #14 of 19 Old 06-21-2008, 08:10 AM Thread Starter
esad_b
Well im gonna have to air down next time down, but yah the problem is about airing back up once i came out id have to go find a pump or something that has air. Well ill guess ill have to try that next time then
thanks guys!
esad_b is offline
post #15 of 19 Old 06-21-2008, 07:52 PM Thread Starter
esad_b
what kind of PSI would you guys recommend for pavement? Right now im at 29.5 or so? Is that good?
esad_b is offline
Help .... Bad Bounce!!!! IrishRED TJ Wrangler Technical Forum 16 06-24-2009 06:48 PM
Amp bounce and pop jake7893 TJ Wrangler Technical Forum 3 01-18-2007 08:57 AM
Bounce JPJeeper TJ Wrangler Technical Forum 20 01-19-2006 08:28 AM
Bounce, Bounce, Bounce Baze YJ Wrangler Technical Forum 7 10-20-2004 08:27 PM
