wheelin gear - JeepForum.com
post #1 of 2 Old 05-30-2008, 06:01 PM Thread Starter
frumpy
frumpy's Avatar
wheelin gear
just wondering what you guys carry for your usual trips. Also if you have storage solution pictures post them up. Just got my new project jeep and have a dog now so I need a little room in the back for the dog and still have my gear back there.
I usually carry
- 30' recovery strap
- emergency 15' recovery strap
- 20' 8000lbs tow rope (for dragging vehicles back, not recovery)
- 5' tree saver
- two big D rings
- co2 10lbs bottle with hose and tire filler
- mastercraft wrench and rachet set
- mechanics gloves
- couple tie downs and couple bungeys
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #2 of 2 Old 05-30-2008, 07:39 PM
Ptr
1992 J-Series Truck
i don't carry anything because im not allowed to wheel yet.
Ptr is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 08:53 AM
Wheelin auto or wheelin stick KJFactor YJ Wrangler Technical Forum 39 07-15-2009 09:39 PM
New Gear Break In..When to Do Initial Gear Lube Change?? Jim93YJ YJ Wrangler Technical Forum 8 10-14-2008 07:59 PM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 01:34 PM
