Quantcast Wheel spacer question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Wheel spacer question
Old 01-06-2009, 03:22 PM   #1
GlennA
I have always thought that wheel spaces put a lot of extra strain on the wheel bearings. Is that true or false? Also, are the wheel spacers that people are using hubcentric or lugcentric?
GlennA is offline   Reply With Quote
Old 01-06-2009, 04:20 PM   #2
Strizzy
I don't see them exerting any more strain than wheels with a comparable backspacing.
-Steve-
2004 TJ Rubicon
OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs -
Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid -
Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid -
Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper
RIP:
2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD.
2 motors, 2 trannies, 150k miles before I parked it.
Jeeps Going Wild
Strizzy is offline   Reply With Quote
Old 01-07-2009, 11:28 AM   #3
wTheOnew
As long as you install them correctly they are basically the same as having wheels with less backspacing. Hubcentric is the way to go.
Georgia Institute
of
Technology
GA Trail Riders
wTheOnew is offline   Reply With Quote
Old 01-11-2009, 06:30 PM   #4
darkpony
x2 on the correct install. There is no difference in loading between a wheel spacer and a wheel with the equivalent backspacing.
"Don't let a little fear and common sense slow you down."
darkpony is offline   Reply With Quote
Old 01-11-2009, 06:33 PM   #5
spyder6
Just violated my Parole
spyder6's Avatar
anyone that tells you they are unsafe or put extra strain on anything vs regular wheels has no idea what they're talking about. if you install them correctly and preform proper maintenance they're as safe as anything else. i have been running mine for 25,000 miles
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Glock Forum
