Whats a TJ worth with a blown motor? - JeepForum.com
post #1 of 20 Old 12-20-2011, 08:21 PM Thread Starter
xj539
So a friend of a friend drove his jeep into a drainage ditch, the whole engine compartment was submerged and locked up the motor.. i went to look at it.. water in the oil. battery is fried. among the other things that happens when a truck dives into the drink.
so my question is.. how much is it worth.. i wanna buy it because i already got a new motor lined up for it.. i offered $500 and his counter offer was $3500 then 2700, then 2200..
Im not high i know im not interested anything close to 1000 with that many problems.. what you guys think>?
xj539 is offline
post #2 of 20 Old 12-20-2011, 08:31 PM
sandfox4
year? miles? trans? options? little more info would help us put a price on it
sandfox4 is offline
post #3 of 20 Old 12-20-2011, 08:32 PM
Doty152
What year and what model?
Roses are red
Violets are blue
They don't think it be like it is,
But it do.
Alcohol may be mans worst enemy, but the Bible says to love your enemy.
ಠ_ರೃ
Doty152 is offline
post #4 of 20 Old 12-20-2011, 08:36 PM Thread Starter
xj539
oh my bad, its a 2000, 95k miles, auto trans, chrys 8.25 rear. brand new 31 in tires. no top, no doors, no lift, scratches, faded paint, no back seat, flares are all banged up...
xj539 is offline
post #5 of 20 Old 12-20-2011, 08:56 PM
Skyryder
Maybe 1K tops, depends on how deep for how long? ECM get dipped or soaked, wiring is a pain to replace, tranny & axles fill up, , etc. Sounds like he is just deducting the cost of an engine, much more involved, plus no top, doors and in rough condition to begin with.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #6 of 20 Old 12-20-2011, 09:02 PM
ABQ-TJ
so you're buying a frame and tub basically?!?
Why does it have an 8.25 rear?!
ABQ-TJ is offline
post #7 of 20 Old 12-20-2011, 09:04 PM
TheDirtyGeneral
someone couldnt find an 8.8
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #8 of 20 Old 12-20-2011, 09:04 PM Thread Starter
xj539
it was in the water for about 2 hours... if i hook up a battery to it, is there anything i can do to check the ecu?
im content with changing a motor, but if wiring and a new ecu gets involved, im not going higher then 500.
what are some things i can check with him there.. i obviously cant take off the sparkplugs in his drive way.. checked the oil, and just water showed up on the stick.. not really sure what else i can do
xj539 is offline
post #9 of 20 Old 12-21-2011, 05:20 AM
greene69
Yea $500 would be all i would want to go, trans may be shot also and wiring doesn't like water. If you hook up a battery see what works, lights, heat fan, etc and see if it blows any fuses.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #10 of 20 Old 12-21-2011, 10:43 AM
TheDirtyGeneral
Honeslty, You're probably only buying a frame tub and axles at this point. You should go into thinking everything else is trashed and then see what you can salvage. I wouldnt pay more than $500 bucks for a tub and frame lol
post #11 of 20 Old 12-21-2011, 12:34 PM
Xpress
You're looking at trying to sell a table stand inside of a jeep... $200 be my tops.
All about that unibody life.
Xpress is offline
post #12 of 20 Old 12-21-2011, 01:50 PM
Mantis212
2010 JK Wrangler
I agree with Xpress even though he chose not to agree with me on another topic
Thats like buying a banged up iphone after its been submerged...well it dont work but you can use the case for it on another phone...pretty much useless.
-Mantis
Mantis212 is offline
post #13 of 20 Old 12-21-2011, 01:53 PM
Driver831
Originally Posted by xpress
you're looking at trying to sell a table stand inside of a jeep... $200 be my tops.
x2
Follow on Instagram kids! @ Driver831 @provinggroundsracing
www.Provinggroundsracing.com
Driver831 is offline
post #14 of 20 Old 12-21-2011, 03:43 PM
giggityjeeper
so you book it like it had an engine, and ding it 3500 bucks to replace the engine....
the rest will prolly be salvagable with some elbow grease
so if its 'was worth say...6ish.... it would now be worth about 2 grand...
REALLY!! ppl 200 bucks give your head a shake, you could not by the rims off it for that for **** sakes.. couldnt even buy a salvaged title for 200 bucks
Itprolly no doubt has a very solid, body, frame, it has a 8.25 that just needs some new fluid, ya could not buy THAT for 200 bucks at a salvage yard.....
I find it funny how an engine could make a vehicle go from 200 bucks to $5000 when an engine is about a grnad to replace.....
as most of us know to replace a 4.0 is not a big job... and for 3500 you could EASILY do it and replace whatever else is needed.....
has anyone TRIED to start it... pull the plugs drainghte water, change the oil and fire it up, you may be surprsed, we hydrolocked a dodge last fall. it was in over night before we could get an H1 into get him out.... we drained it there, dried it, brought oil and drove it home
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #15 of 20 Old 12-23-2011, 08:14 AM
raybob
I buy Flood damaged vehicle's all the time. I would start by pulling spark plugs, manually turn engine over until all water is pumped out of cylinders. If it turns then the engine will be fine. As for water in the oil, just change it. Replace electrical parts as needed, jeeps don't have that many electrical parts to go bad. I suppose this is a Cherokee, by the 8.25 rearend? I have a few for parts if you need any electrical stuff.
raybob is offline
Blown head gasket actually a blown motor :( KidFresh TJ Wrangler Technical Forum 8 01-11-2010 09:11 PM
Motor blown help digitalrob TJ Wrangler Technical Forum 32 10-03-2006 03:01 PM
97 TJ with bad motor, whats it worth windmill TJ Wrangler Technical Forum 13 04-23-2006 10:28 PM
4th blown starter, whats up with that!? ginsy YJ Wrangler Technical Forum 12 04-18-2005 09:01 AM
What do you guys think it's worth? 94 Yj BLOWN Engine! Tbones YJ Wrangler Technical Forum 5 11-22-2004 05:05 AM
