What is this wire for? - JeepForum.com
post #1 of 1 Old 09-14-2010, 08:41 PM Thread Starter
EpicUnlmtd
I just took off the trim piece above the dashboard and running along the base of the windshield to check out how to replace the radio and on the passenger side I found a run from the wiring harness with about 8-10 wires(back together and I didn't count them at the time) and ending with a white connector. Can anyone tell me what accessory this connector is for? A more comprehensive list of the wiring would help immensely as I am trying to figure out a radio install with iPod, satellite, etc. and being able to pull power from there would be nice. Thanks in advance for any help.
EpicUnlmtd is offline
dash , wiring , wiring harness , wrangler
2 wire LEDs to 3 wire conversion (write up) zachjf TJ Wrangler Technical Forum 148 02-07-2017 08:31 AM
Anyone ever mastered the 3 wire turn signal rewired to the 2 wire LED Rippers TJ Wrangler Technical Forum 28 06-08-2016 01:29 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
95 YJ--Which wire is the crank(start)wire?? jnkyrdg04 YJ Wrangler Technical Forum 0 03-09-2007 01:27 PM
