What sorta compressor for U-Pol Raptor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > What sorta compressor for U-Pol Raptor
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOffset Tie Rod Kit From RuffStuff!
Unread 07-17-2009, 08:16 PM   #1
sailsurf7713
Kind of kicked the crap out of my tj's interior using it as the rugged versatile vehicle that it is and would like to raptor line it.
I've got a 3 hp craftsman compressor with a 30 gallon tank? Would like to know if this is up to the task of lining the tube before spending a hundred bucks on this stuff.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
My Rusty Revival
sailsurf7713 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2009, 08:03 AM   #2
Imped
Imped's Avatar
I'd also be interested in knowing what others have used.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-19-2009, 05:00 PM   #3
timmyt
bump.............
2006 LJ Rubicon. 2.5"RC BB/BL kit. 285/75/16 BFG KM2's on Moabs.
timmyt is offline   Reply With Quote Quick reply to this message
Unread 07-21-2009, 08:00 PM   #4
93jeepyj
That compressor will probably be fine. The cfms the comp. puts out is more important here, youd need to look at what the u-pol gun requires to find out if the compressor will keep up with it.
93jeepyj is offline   Reply With Quote Quick reply to this message
